VG-8 with the GR-20
Started by Ciaron, October 19, 2015, 06:51:41 AM
Ciaron
Hi all,
I'm a recent convert to the VG-8, I loved it so much I bought two!
I'm now looking at adding some additional synthesis to the mix in the form of a GR-20.
My question is, what's the best / easiest way to hook them up so they can be used together?
For the band I'm currently playing with I'll be predominantly using the VG-8, but there are songs that would benefit from just piano / string sounds.
Can I link them via midi, or do I need some kind of splitter cable from the guitar?
Any help would be greatly appreciated.
Thanks in advance.
Ciaron
QuoteMy question is, what's the best / easiest way to hook them up so they can be used together?
Roland US-20 GK13 A/B/Y Selector box
https://www.vguitarforums.com/smf/index.php?topic=13953.0
or third party versions here
https://www.vguitarforums.com/smf/index.php?topic=10935.0
Ciaron
Definitely need to split the 13 pin GK signal to both units.
You can run the VG-8 output into the GR-20, and use the GR-20 to control the mix between VG-8 and GR-20,
and use the GR-20 'summed' output (of both VG-8 & GR-20) mixed to a single stereo out.
Likewise with the VG-8
After you employ the Roland US-20 A/B/Y Selector switch, You can run the GR-20 output into the Aux IN on VG-8, and use the VG-8 to control the mix between VG-8 and GR-20,
and use the VG-8 'summed' output (of both VG-8 & GR-20) mixed to a single stereo out.
Tony Raven
 :o
I would never have thought of that.
