FTP, Ipad Air and Behringer FCB1010 (midi foot controller)
Started by FilT6969, October 08, 2014, 12:09:50 AM
FilT6969
 I have an ipad air, a fishman triple play on my guitar with dongle connected via cck to ipad. I want to buy a Behringer FCB1010 (midi foot controller), but how should I connect this device to my ipad? Sorry for crossposting. (I did a search but did not find the answer)
You need a powered USB Hub (output feeds the Apple CCK.)
Survey of USB Hubs
https://www.vguitarforums.com/smf/index.php?topic=10326.0
and USB Class compliant USB<>MIDI cable to connect the FCB-1010 to the powered USB hub
USB Class Compliant MIDI Cables
READ
Connecting USB Audio Interfaces, MIDI Controllers, and Keyboards to the iPad
http://www.akaipro.com/kb/article/1502
FilT6969
Quote: you need a powered usb hub (output feeds the Apple cck): so I need to use a usb A to usb A cable to connect the hub with the cck?
StanD
Elantric,
I'm going to get a Fishman Triple Play tomorrow. Want to set up a live rig with Trip, FCB1010 and Ipad.
Any current recommendations?
I have an Irig Pro I'm not sure that will help in connecting as I don't see a way connect the FTP USB dongle to it.
Following your extensive posts (thank you) I'll need a USB compliant hub and midi to usb cable for the pedal and a usb to lightning to go to the ipad.
Also I will be running a Marshall JVM which has midi. It seem like I could use separate midi channels for the amp and ipad and turn on ipad sounds and while shutting off the amp (effects loop 100% on no pedal) with one stomp on the FCB1010. Wow that would be cool.
You need an Apple USB Camera Adapter( I prefer the latest version ) + powered USB Hub
Use the USB cable for IRig Pro
Add a Roland UM-One MK2 USB <>MIDI CABLE
Or replace both IRig Pro and UM-One with Roland UA-22
Read the whole thread here
