2017 Winter NAMM - January 19–22, 2017.
Started by Litesnsirens, December 27, 2016, 09:13:31 AM
http://digitech.com/en-US/products/dod-mini-expression
DOD Mini Expression
Expression Pedal
The new passive DOD Mini Expression Pedal is just the right size for your pedal board, and your wallet. Rugged all-steel construction and gear drive means that there are no strings to break. Despite its compact form factor it is designed to have the same feel and throw as pedals that are twice its size (and price).
More Details
The Mini Expression Pedal features a TRS (25kΩ)/TS (10kΩ)/RTS (25kΩ) selector, making it flexible to work with most gear with expression pedal inputs. The non-slip rubber pads, and a peerless industrial design by DB Instrument Amp insure a high quality expression pedal that will last the test of time.
Features
Gear Drive for reliable performance
3-position multi resistance for wide range of compatibility
Linear 25kΩ/10kΩ potentiometer
Ultra Compact size has same footprint as most pedals
Specifications
Dimensions   5.00" (L) x 3" (W) x 2.40" (H) / 127mm (L) x 76mm (W) x 61mm (H)
Weight   ~1.1 lbs. / 0.5 kgs.
Output   (1) ¼" TRS/TS Instrument
Chassis   All Metal
Headless68
Any detail on the new variax guitar - any enhancements or just a different style ?
QuoteAny detail on the new variax guitar - any enhancements or just a different style ?
http://line6.com/variax-modeling-guitars/shuriken
Baritone Variax  Shuriken
Its a longer 27" scale length guitar  - and natively tuned Baritione
new DSP Algorthms have been adapted for this specific model
by contrast on a Tyler Variax ( or 2015 Variax Standard) - if you tune it to Baritione tuning - you get warbles in the DSP Alt Tunings
QuoteIf you like to perform with heavier strings and lower tunings, Variax Shuriken features a 27" baritone scale length that delivers optimized playability and punchier, more-precise tones. The extended scale length also works in conjunction with Variax alternative tunings—so you can play in any tuning, regardless of the tension and feel of the strings. With Variax Shuriken, you can go far beyond the range of any standard 6, 7 or even 8 string guitar.
http://padalka-guitars.com/portfolio-items/shuriken/
Spider
I asked Stevic MacKay about Shuriken: it will be less expensive then 2014 Shuriken priced 2000-3000 AUD and... 1) he use it in standard Drop D tuning plus "27" scale and bridge tracks better than any Variax to date."
mchad
Harmony Central. Coverage by Bieke.
http://www.harmonycentral.com/forum/forum/trade-shows/winter-namm-2017/31899449-namm-rumours
Yer I know. Harmony Central resides in the history of the internet! Right? Well they appear to have heaps of gear news from NAMM. Plough through it at your own risk.
QuoteHarmony Central. Coverage by Bieke.
I'll check if MySpace.com has any NAMM coverage ;)
I'm starting NAMM day #2
https://www.kickstarter.com/projects/947616293/tone-shifter-smart-sound-interface
Yesterday saw a prototype of Tone Shifter Mega
a cool USB CLASS COMPLIANT Audio /MIDI foot controller/audio interface that appeared to be a good solution for iPad/iPhone BIAS /YONAC TONESTACK USERS
And very impressed with Mod Duo and new Centerpoint XL Powered speaker.
More soon
Cool! Keep us posted... Enjoy day 2
JoBoss
Quote from: Elantric on January 21, 2017, 09:46:01 AM
Yesterday saw a prototype of a cool USB CLASS COMPLIANT Audio /MIDI foot controller/audio interface that appeared to be a good solution for iPad/iPhone BIAS /YONAC TONESTACK USERS
More soon
Would that prototype cool usb class midi controller be from Boss/Roland?..Whats Boss/Roland's take this winter?  Hoping for a GP-10 overhaul with regard to class compliance......or is that possible now?........
QuoteWould that prototype cool usb class midi controller be from Boss/Roland?
No
China
Tone Shifter Mega
http://www.tone-shifter.com/
vtgearhead
It's RME ,probably $900
https://www.rme-audio.de/en/products/digiface_usb.php
https://www.sweetwater.com/insync/rme-digiface-usb/
The RME Digiface USB portable digital audio interface provides top-shelf sound and powerful features that you can take anywhere. This interface takes RME's famous HDSP Digiface and improves it with USB 2 connectivity, bus power, and expanded I/O. Each of the Digiface USB's four optical inputs/outputs accepts either ADAT or S/PDIF. SMUX and SMUX4 are supported, providing the utmost in flexibility. Routing and monitoring is a piece of cake, thanks to RME's powerful TotalMix FX. And RME's legendary stability and reliability ensures worry-free performance.
http://www.premierguitar.com/articles/23645-tone-shifter-unveils-worlds-first-smart-sounds-interface
Old version above:  ^
Yesterday saw a prototype of a cool "TONE SHIFTER MEGA" USB CLASS COMPLIANT Audio /MIDI foot controller/audio interface that appeared to be a good solution for iPad/iPhone BIAS /YONAC TONESTACK USERS
This pedal is very cool!
http://digitech.com/en-US/products/freqout
Create Feedback at Any Volume
Use the DOD FreqOut pedal to coax natural-sounding feedback from your guitar amplifier at any volume, with or without distortion. You even have control over the harmonics that are highlighted, leading to amazingly musical results. The sound is full and huge, just like a howling guitar amplifier. The footswitch can be set for momentary or latching operation, and you can choose whether your dry signal is mixed with the effect. When you want to generate feedback in low-volume situations, Sweetwater highly recommends the DOD FreqOut feedback creation pedal.
Pitch detection technology gives you control over feedback frequencies
The DOD FreqOut pedal uses pitch detection technology to constantly monitor the harmonic content of your guitar signal. You can select from seven different harmonics to highlight (Sub, 1st, 2nd, 3rd, 5th, Nat Low, and Nat Hi) which determine the character of the feedback effect. When you switch FreqOut on, it generates natural-sounding feedback that focuses on the harmonic mode you've selected.
DOD FreqOut Feedback Creation Pedal Features:
Generate natural-sounding amplifier feedback at low volume levels, with or without distortion
7 harmonic modes give you control over which frequencies are highlighted in the feedback
Dry signal can be mixed with the effect or turned off for effect-only operation
LED indicators display feedback signal level
Footswitch can be toggled between momentary and latching operation
True bypass switching removes the effect circuit from your signal path when disengaged
Onset and Gain controls to fine-tune the feedback behavior
http://www.get-a-backbone.com/default_v3.aspx
How It Works
BACKBONE GUITAR RESONANCE ENHANCERS are direct bolt-on replacements for the stock neckplates of Tele and Strat style guitars. The 6 3/4" Stratobone and 11 1/4" T-Bone extend to form a resonant, mechanical link between the neck pocket, bridge and strings. Machined from lightweight aircraft aluminum, their revolutionary, patent pending design produces greater clarity, improved tone, longer sustain and enhanced resonance. Simply attach Backbone in place of the neck-plate and connect the base to the string ferrules or tremolo claw. The improvement is immediate. Teles sound more bell-like. Strats have more chime. Acoustically, your guitar will sound more alive, and your pickups will 'hear' more than ever before.
TWO MODELS - NO MODIFICATIONS TO THE GUITAR Stratobone for Strat-style, and T-Bone for Tele-style, they fit any guitar using the industry standard dimensions for bolt on necks. Invented and crafted in the USA, Backbone is affordable and totally non-invasive, providing the resonant qualities of a neck-through design combined with the sound and feel of your favorite guitar.
TONE BLOCK "MATERIAL TONAL DIFFERENCES" The Brass Tone Block produces a balanced frequency spectrum suitable for all playing styles from Rock, Pop and Country. The Aluminum Tone Block accentuates mid to high frequencies delivering a more aggressive, Metal sound. Introduced at the Winter NAMM Show, the Graph Tech TUSQTM Tone Block provides a more mellow, balanced tonal spectrum with slightly extended harmonics ideal for Blues, Jazz and Country.
Backbone units are direct bolt-on replacements for the stock neckplates of Tele and Strat style guitars. Extending from the neck-plate to the string ferrules on Teles and tremolo claw on Strats, they create a resonant, mechanical link between the neck, bridge and strings. Machined from lightweight aircraft aluminum, their patented, revolutionary design produces greater clarity, improved tone, longer sustain and enhanced resonance, fitting any guitar using the industry standard dimensions for bolt on necks. Invented and crafted in the USA, Backbone is affordable and totally non invasive, providing the resonant qualities of a neck-through design combined with the sound and feel of the world's most popular guitars
ZenSonic
I can see some applications for this pedal right off the bat! Looking forward to playing with it. thanks
The best Les Paul under $150 new
Monoprice Indio
supernicd
Just wanted to say "Thanks!" as always, Elantric, for your NAMM summary.   Always a nice concise view of the important stuff here!
Strat w/ GK-3, Godin LGXT
VG-99, GR-55, GP-10
