Build your own US-20
Started by Elantric, March 07, 2008, 02:04:39 PM
Here's an old doc in my collection I did not compose this!
Wow. It looks as though I was all wet about balancing the impedance between
the two units and the GK pickup. The schematic shows that 6 signals coming
from the GK pickup are simply wired directly to both unit A and B. The only
impedance balancing and buffering that is occuring is for the guitar's
pickup and the GK volume control signal.
So, sports fans, if you wanted to build your own stripped down "US20", and
you use external volume controls for the two units, you can simiply omit the
volume control connection. The MIDI values over-ride the setting on the GK.
Also, you can the guitar signal to only ONE of the units, or, don't connect
it at all, run it straight to the board. Use the power from only ONE of the
units and you're set.
Of course you lose all of the functionality of the GK. I don't use any of
it anyway. Here's my wiring list in GK pin number order:
GK          UNITA          UNITB
SIG1       SIG1            SIG1
SIG2       SIG2            SIG2
SIG3       SIG3            SIG3
SIG4       SIG4            SIG4
SIG5       SIG5            SIG5
SIG6       SIG6            SIG6
GTSIG     N/C             N/C       ->Direct to board
SYVOL   N/C             N/C
NC
S1           N/C              N/C
S2           N/C              N/C
+7V        +7V              N/C
-7V         -7V              N/C
Harald Milz wrote>
http://www.muc.de/%7Ehm/music/us-20/
Schematics
The schematics is derived from the original Roland part whose schematics if available in the GR-30 file area on yahoogroups. I made two modifications:
    * My clone has the guitar out, and the guitar signal is not routed to the attached GK accessories.
    * Roland did not adhere to its own standards when designing the US-20, see here. The volume buffer has now the 68K resistor.
The Eagle files linked below are Copyright Harald Milz 2001, and put under the GNU General Public License. Commercial use requires a license from me which has to be negotiated, and a license from Cadsoft which is available from their web site. If you make any modifications please send them to me to allow me keeping track of what you did.
The PCB was designed and mostly autorouted using Eagle. The Eagle files are here. A free version of the Eagle layouter for educational use is available from Cadsoft. (Remark: these are the files for board revision 2. The files for rev. 1 are here.) If you have no means to make a double-sided PCB with through contacts I can have some PCBs made for you. They are about 50 DEM each.
Parts
The Eagle partlist is here. The toughest part is getting the 13-pin plugs. In the U.S. they are available from Digikey. In Germany, Reichelt has them. I bought some in Munich (Holzinger, Schillerstrasse).
PCB Assembly
My prototype worked out of the box so it should be quite DIY safe. Rev 1 of the board contains some errors which have been corrected in Rev. 2. Rev 1 is not longer supported except for people who bought the PCB. New projects should always get Rev. 2 from the links above.
Footswitches: I reused a DPDT switch from an older stompbox, and bought a new SPDT switch. Simply solder some 3-wire flat ribbon strands to the solder terminals on the PCB and the respective terminals of the switched (see pic above). The sequence doesn't matter just make sure the middle terminal on the PCB is connected to the middle terminal of each respective switch.
Alternatively, you can connect 2 relays (DPDT and SPDT, respectively) and have them switched by a MIDI device. This way you can change the settings using MIDI. I don't know how much current you can draw from a GK device (the US-20 draws +/- 7V from port A) so be sure not to spoil your GK toys. This is not for the beginner! You have been warned.
The GK Cable
Warning:If you don't have a very fine soldering iron with a sharp tip (10-15W is appropriate), excellent soldering skills, and very calm hands don't even dream of making this yourself.
If you have 2 GK compliant devices it is likely you have one spare GK cable. The easiest way to get 2 short (1 - 1.5m) cables is to cut the spare cable in halves, and solder 13-pin male plugs to the bare ends.
Plank has got a file showing the colorcode to pin assignment in the a.m. file area. It is sort of useful to give you a rough idea but my cable had completely different colors and pin assignments. Use an ohmmeter to find the assignments and document them for your use. There is no magic to this - just make sure all colored wires are soldered to the same pins on both sides, respectively.
Test setup
Soldering the tiny wires to the male plug isn't trivial. My plugs just had 13 pins on the backside, no soldering pockets! Be sure not to use too much solder otherwise you run the risk of getting shorts which can put your precious Roland parts on risk! Double check the wiring! Use a bench vice or something to properly fix the plug before soldering. Otherwise your mental state is on risk.
In order not to get any shorts within the plug you may want to wrap some isolating tape around all pins, or use a thin isolating plastic tube.
Testing 1 - 2 - 3
Lotsa warnings. Don't worry if you have good EE skills. I built the interface including the cables in slightly more than 3.5 hours (the case is still missing, though), and double and triple checked everything to be on the safe side.
Final assembly
Built in a Teko 362 case which is shielded with alu foil, it finally works fine :-)
The PCB mounted to the frontpanel. Since the panel is only 1mm alu I reinforced it with a 1.5mm alu strip.
View from the side. You can see the sandwich-like construction.
US-20 clone and faithful companions...
Another US-20 clone project, albeit without a PCB.
To my other electronic projects
Harald Milz
Last modified: Sun Mar 9 20:01:31 CET 2003
chamav
Hi,
I was thinking of building a simple 1-in/2-outs parallel box myself similar to the GKP-4 unit. My simple requirements are to fully drive the first output (VG-99) with all the GK output signals of the guitar and drive the second output (GR-33) only with the S1-S6 signals (the synth volume will be controlled on the GR-33 itself).
Here are my questions:
1. I understand from the US-20 schematics that the S1-S6 signals could drive both units in parallel, i.e. no op amps are required, correct?
2. I am wondering about the other output signals 7-13 of the GR-33 unit. Should I leave them open? Especially what should be the case for the VOL (in order to have the max value), SW1 and SW2 (in order to be inactive)?
I attach a very simple schematic of my idea.
Thank you
Just finished building my own US-20. Buttons on the unit are always S1/S2 for the GR-55.
Insert for regular guitar also included.
Works great.
Ha..
...you & I are doing the same stuff!   :D
..The Behringer unit is very adaptable for a number of functions and I've been playing with a couple of these for a while..decided to go down this road when I realised I could buy 2 half-reasonable foot switches for a fairly cheap price like this without going to the trouble of manufacturing my own design just yet.   ...maybe next year for that one... ::)
I found I could hack this thing really easily to fit my own Synth-Linx jacks without a great deal of heartache or effort..    ...a holesaw is all it takes and I can fit my jacks with the mounting flange internally so all the wiring can be pre-made without having to pass it though the hole in the case.. 8)
...it is also fairly easy to gang these things so you can get 4 footswitches in a row if you want to play dirty...   for me, I find that (particularly in a stage setting) I am more comfortable with the feel of these switches than momentary stomp buttons, although that may be an age thing.. ;D
Look forward to hearing how you get on with it over time..
cheers,
Peter
CodeSmart
Looks GREAT Sixeight ;D!!!
I agree with Peter, the switches are really nice.
I couldn't find a manufacturer making something like this when I looked last year :(
I've just put the two 13-pin cables on the mail box, you will have them soon to go with that nice box.
Thanks a lot Robert. It just great I don't have to solder those myself.
6dB
I think the A/B switching can be done all mechanically with a 4pdt switch:
-1 switch for the S1
-1 switch for the S2
-1 switch for the SYNTH VOL
-1 switch for A/B led status
The rest of the circuit is the same
Should work right?
Quote from: 6dB on December 11, 2017, 03:41:53 PM
Should work right?
Need one more switch leg to move the Pin#8 SYNTH (GK VOL) line as follows:
* To Select Unit A  = must MUTE Unit B using the Unit B Pin#8 GK VOL (SYTNH VOL) line @ 0VDC
* To Select Unit B  = must MUTE Unit A using the Unit A Pin#8 GK VOL (SYTNH VOL) line @ 0VDC
* To Select both Unit A and B  = must tie the source GK VOL (SYTNH VOL) (0 to 5 VDC range)  line to feed both UNit A and Unit B Pin #8 on both.
The US-20 works by muting SYNTH VOL on the unused GK Processor
6dB
Quote from: admsustainiac on December 11, 2017, 03:52:45 PM
In a 4PDT there are, well 4 SPDT switches with 3 lugs each so i was guessing that in the case of the SYNTH VOL row of switches, GND (coming from the BOTH switch) goes to the center (common) lug, and each of the outer lugs go to each junction of 1k and pin8 for each unit out. It is almost the same way as a regular A/B/Y box works.
this is the 4PDT Stompswitch i´m referring to
Piing
I am going to build a GK splitter without the US-20 selector features.
I wanted to use chassis mounted female DIN connectors, to solder the wires directly, but I couldn't find them. So I bought the PCB angled version
Anyone has the drawing of a PCB for this purpose? There are some electronic shops here in Bangkok that make PCBs for a good price, but I have to provide the drawing
Can't help you with a PCB drawing (and remember there are MORE THAN ONE version of these jacks, and they DO have differing PCB pin layouts)....BUT...
...as you will see from :-
https://www.vguitarforums.com/smf/index.php?topic=8888.0
...I have been building these for 10 years and selling via this Forum for over 7 years...
Email me at :-     info@synth-linx.com.  and we can talk about possible options; I am in Australia.
Regards,
Peter
Piing
Thank you for the information, Peter.
I've already ordered these for just 0.54 USD each, 0.18 USD shipping on AliExpress
https://www.aliexpress.com/item/4000600409373.html?spm=a2g0s.9042311.0.0.5c674c4dbwRZIk
First I will check if they can fit into a prototype board, otherwise I will have to work a PCB
QuoteAnyone has the drawing of a PCB for this purpose? There are some electronic shops here in Bangkok that make PCBs for a good price, but I have to provide the drawing
I still have some PCB's lying around for a 3-way splitter. PM me if you are interested.
Piing
#14
Thank you for providing the PCB @sixeight. It is working perfectly. It is a pleasure to play simultaneously with the VG99 and the SY-1000  :) :)
Since I am only using two outputs, I have used the pins of the third output to redirect strings 1-6 to six jacks, to process the strings separately at the Axe-FX III. However, there is an awful noise as soon as I connect the SY-1000 at the first output (to have power supply at the GK-3). All the Axe-FX meters go to red.
How is a 6-string breakout box supposed to work? Should it have an independent power supply for the GK, in order to avoid taking it from the SY or the VG?
Piing
#15
I've found the problem. Since I was not planning to use the third GK output, I did not connect the jumper JP3  ::)
Well done !  ;)
Cheers,
Peter
#17
Quote from: Piing on September 22, 2020, 01:54:02 AM
Nice work! Glad to see you have it all working.
If you find the normal pickup not working, make sure you put a jumper on P6. The idea here it that you can create an extra in and output for the normal PU signal.
