Guitar to MIDI On/Off setting per patch?
Started by ddlooping, August 25, 2010, 08:06:44 PM
ddlooping
Quote from: Brent Flash on August 28, 2010, 07:45:04 AM
What I am meaning is that it does not play...
It does work, if that's what you mean, I'm using it right now. ;)
Whether it is due to the XV-5050 prioritising the Program Change sent to its Control Channel to the same one sent to the Patch (within the Performance) sharing the same MIDI receive channel (RX) I don't know, but it does work. :)
Quote from: ddlooping on August 28, 2010, 08:06:52 AM
Yes, when there is a will there is a way. Early owners of the VG-99 went through the learning process to get around these little issues in this thread a couple of years ago, you may want to skim through it. https://www.vguitarforums.com/smf/index.php?topic=915.15
ddlooping
Quote from: Brent Flash on August 28, 2010, 08:57:45 AM
Thanks Brent, I'll give it a read. :)
