GT-100- Trouble with assigns and accel/ctl pedal
Started by mhayden37, September 30, 2017, 07:27:42 AM
mhayden37
Hi
I just purchased a GT-100. I'm sure this has been covered but despite following the manual and YouTube videos, I'm still struggling with assign function and the accel/ctl function.  I believe I have turned the accel function off and tried to assign some parameters to that footswitch, but every time I push the accel/footswitch, I still get the accel function (in this case a rotary effect).  It doesn't appear to trigger what I have assigned to the pedal either. That's problem #1.
Problem #2 is more of a question of how-to.  I'd like to use the expression pedal as such:
When switching "on" it turns off the distortion block and turns on the Wah.  When I switch it "off" it turns the distortion block on and the Wah off. Is this possible using the "assigns" function?  Any help would be greatly appreciated!
mhayden37
Ok, I was able to fix the assigns so that the Accel/CTL works to turn EQ on and off when I push it when in "PLAY MODE."  When I switch to manual mode so I can use footswitches for multiple effects, the accell/ctl always functions as accel.  This is within the same patched that I have saved as user preset 1.  Should this preset work regardless if I'm in play mode or manual mode?  Again, any help would be greatly appreciated.
There is a setting for Manual mode pedal functions, so if you don't want manual mode to over-ride the assign, then in the function settings for manual mode, switch off the Manual Mode function for Accel Pedal.
An alternative GT-100 editor might help with better graphical layout of the GT-100 functions.
https://sourceforge.net/projects/fxfloorboard/
mhayden37
Thank you! I will give the settings a try and take a look at the interface.  Much appreciated.
mhayden37
Quote from: gumtown on September 30, 2017, 03:07:15 PM
Can you give me a little direction as to where the setting is for manual mode pedal functions? I am currently just using the unit to make changes and do not use a computer at this point.
Thank you
My GT-100 is out on loan at the moment, in the FxFloorBoard software, the settings for Manual Mode Function are under Master controls section.
The Manual Mode functions are settable per each patch.
