2017 Superbooth / MusikMesse
Started by Elantric, March 29, 2017, 08:49:28 PM
Arturia will be attending both Musikmesse in Frankfurt and Superbooth in Berlin next month, where we will be showing off our latest equipment, software, and synths, as well as dropping some very, very exciting news. We look forward to seeing you there.
https://www.arturia.com/company/news/events
A Variation on the old US Robotics Beam Forming conference room microphones - but this one is multichannel
http://www.musicradar.com/news/musikmesse-2017-zylia-promises-to-let-you-make-studio-quality-multitrack-band-recordings-with-a-single-microphone
It sounds like magic, but the new creators of the new Zylia 'portable recording studio' say that their system enables bands to record their performances with a single microphone, and then mix them as multitracks using dedicated software on PC, Mac or Linux.
The Zylia ZM-1 is billed as a USB multitrack microphone that features 19 mic capsules and supports 24-bit/48kHz recording. The Zylia Studio software, meanwhile, extracts the individual instruments onto separate tracks so that you can mix them or export them individually into your DAW of choice.
Zylia is billed as the perfect solution for bands who want a quick and easy way of capturing their rehearsals and live performances. The set up time should be pretty much zero, and there's no need for multiple mics and an interface.
Zylia will be on show at Musikmesse, where we'll endeavour to find out more about it. In the meantime, you can check out the Zylia website, where pre-orders are currently being taken for $999.
http://www.zylia.co/zylia-zm-1.html
ZYLIA ZM-1 is a special type of microphone that was designed for multi-track music recording.
​Main features of the microphone:
- High quality audio recording
- 19 microphone capsules
- Durable casing
- LED ring status indicator
- 48 kHz / 24 bit recording
- USB connectivity
- Easy to deploy
​​Gain adjustment: -12dB to +32dB (0.5dB step)
Size: high 155 mm (6.1 inch), length 103 mm (4 inch)
Weight: 470 grams (16.6 ounces)
GENERAL SPEC
​​Number of simultaneously recorded tracks / sources:  Unlimited
Automatic separation of recorded sound sources
Automatic removal of background noises
Recording time: 3 GB / hour (ZYLIA lossless compression, 44.1 kHz, 16 bit), 0.5 GB / hour (MP3, 44.1, 16 bit)
A/D conversion: 24 bits, 44.1 / 48  / 96 kHz
PHYSICAL
DATA TYPE
Storage - Mac or PC through USB
Connection - USB 2.0
Power - Micro USB 2.0
Input  - Unlimited number of Virtual microphones.
Output - Micro USB 2.0
​Quantization - 16 / 24 bit
Sampling frequency - 44.1 / 48 kHz
RAW - Wave / PCM (ZYLIA Studio can export data to wave format 44.1 / 48 kHz, up to 32 bits or float 32)
Data are stored using ZYLIA lossless compression - with ratio 50% of original size
Desktop application for MAC, Linux and Windows
Create, cut and store your recordings
Extract individual instruments into separate tracks
Create a balanced recording by mixing individual instruments
Produce stereo tracks in WAV (wave format 44.1 / 48 kHz, up to 32 bits or float 32)
Export tracks into any DAW software
Free software updates
http://www.musicradar.com/news/musikmesse-2017-mooer-announces-tender-octaver-pro-mod-factory-pro-baby-bomb-30-and-red-truck-pedals
http://www.effectsdatabase.com/model/mooer/redtruck
Mooer Mooer Mooer!
MUSIKMESSE 2017: There's just no stopping Mooer; after a storming NAMM thanks to the Ocean Machine
http://www.musicradar.com/news/guitars/namm-2017-hands-on-review-mooer-devin-townsend-signature-ocean-machine-647619
delay/reverb and 10-strong mini preamp series, the Chinese company has unveiled four new guitar effects pedals that further expand its remit.
New offerings include long-awaited Pro, dual-footswitch'd versions of the Tender Octaver and Mod Factory, plus the Baby Bomb 30 power amp to accompany the aforementioned preamps.
Also notable is the Red Truck, a multi-effects that packs versatile boost, overdrive, distortion, modulation, delay and reverb effects into one compact unit.
All four pedals are available from 30 April - head on through the gallery for the lowdown on each one, including pricing, and visit Mooer Audio for more info.
http://www.mooeraudio.com/
http://www.mooeraudio.com/?product/201611238616.html
Micro Drummer
Having trouble keeping the groove?
In need of a drummer?
Want a practice companion?
Fear not, reach into your pocket and pull out the MOOER micro drummer!!!
Micro drummer is a compact drum machine that slots right into your pedal chain. Sporting 121 drumbeats which span a wide variety of different musical styles and can be synced up to your desired time easily using the on boad tap tempo. Never miss a beat with MOOER micro DRUMMER!!!
Controls
MODE: Selects style and drum pattern. Press to switch between style and pattern parameter. Rotate to change parameter value.
PP:Pop; RC:Rock;  MT:Metal;  BL:Blues;  RB:R&B; JZ:Jazz,
FK:Funk;  LT:Latin; RG:Reggae; PK:Punk; TP:Tempo (metronome)
When the LED is red you can change the style by rotating the MODE control.
When the LED is Blue you can change the pattern by rotating the MODE control.
VOLUME:Adjusts the volume of the Micro Drummer.
SPEED:Adjusts the speed of the Micro Drummer.
TONE:Adjusts the tone of the Micro Drummer.
TAP:2 ways to use Tap Tempo
1、Tap the button in time with the tempo you wish the micro drummer to play.
2、Hold down the footswich for 1 second while the pedal is engaged to enter 'tap tempo' operation, quickly tap the tempo you want the micro drummer to follow.
Specification
Input:1/4" mono audio jack.(Impedance: 470k Ohms)
Output:1/4" mono audio jack(Impedance: 100 Ohms)
Power requirements: AC adapter 9V DC , center negative. Highly
recommend to use Mooer Micro Power.
Current Draw:95mA
Dimensions:93.5mm(D) x 42mm(W) x 52mm(H)
Weight:151g
http://www.mooeraudio.com/?productlist/2014XinChanPin.html
http://www.musicradar.com/news/musikmesse-2017-daddario-debuts-mini-chromatic-pedal-tuner
MUSIKMESSE 2017: The world of guitar tuners is hotly contested - as our round-up of the best examples attests - but D'Addario has used its considerable tuning pedigree to enter a new mini pedal tuner into the fray.
Besides its lightweight, compact build, the imaginatively named Chromatic Pedal Tuner features a vertical-sweeping LED pitch display for a "clearer, more intuitive read".
D'Addario is bigging up its 32-bit chip, which has four times the processing power of a regular headstock tuner for a faster, more accurate readout, with a smoother display.
True bypass switching and 9V power supply operation are also onboard.
The D'Addario Pedal Tuner is available from 1 June for £92 in the UK, and 1 May for $119 in the USA. See D'Addario for more.
I may visit the Pro light and sound and Musik Messe on Friday. But I will only manage one day. The main focus will be on the Pro light and sound halls. I may have a little time left for the guitar halls.
Anybody else visiting on Friday?
Got word that Boss Guitar products will NOT be attending 2017 Musikmesse this year
Quote from: Elantric on March 31, 2017, 09:06:03 AM
I am more disappointed I could not find Atomic, Line6 or Audiosprockets on the exhibitor list. It does suprised me that Roland does not pop up either in the list. Yamaha is all over the place...
vanceg
A beamforming microphone for the masses!  Pretty damn cool!
Quote from: Elantric on March 29, 2017, 08:52:06 PM
- Durable casing
- USB connectivity
- Easy to deploy
GENERAL SPEC
PHYSICAL
DATA TYPE
http://www.sonicstate.com/news/shows.cfm?show=MESSE%202017
Comprised of 3 stereo inputs, an effects send and return loop and a USB audio interface the Keylargo is a simple but effective way to get your multiple keyboard sources into one mix.
The USB interface allows you to take the audio from a computer and mix it easily without the need for a separate interface. The Keylargo also has a monitor and main output control which allows you to easily level your stage monitors against FOH.
More info at Radial Technologies
http://www.radialeng.com/
Combining pitch/frequency shifting, spectral warping, reverbs and dry/wet morphing you can really get some interesting effects out of the Zynaptiq Wormhole.
In this video Denis gives us an overview of the features and also some background into the way in which the effects are made, which in true Zynaptiq fashion is not the most traditional way.
More info at Zynaptiq
http://www.zynaptiq.com/wormhole/
Pons Guitars - Worlds First Interchangeable Body Guitar
This is one those things that you probably wouldn't find at any other trade show. The Pons Revolution Guitar is an interchangeable body guitar and a world first according to Pons.
Basically if you can't decide if you want a Les Paul or a Strat, you can now have both... Or if you want a flying V you can have that too, all at a fraction of the cost of buying everything.
For more info go to Pons Guitars
http://www.ponsguitars.com/
First Touch Screen Performance Effects Module For Eurorack Ships
1010music fxbox combines 16 realtime effects with various aspects of control
1010music tells us that their eagerly anticipated fxbox has begun shipping to dealers and customers. This is what they have to say about it...
This 26HP eurorack module was shown at NAMM and lauded for adding refreshing performance effects options to the eurorack format. fxbox combines 16 realtime effects with control via touch screen, continuous knobs and external modulators. An XY pad lets you control three different aspects of the sound at once to let you morph your sounds in realtime and an internal step sequencer provides yet another way to create tricked out, remix effects. Create complex layers and builds using the touch screen to isolate individual effects. fxbox breathes new life life into pads and other sounds, and can add alternate timing and variety to rhythmic parts. It also can use external clock or MIDI to sync with other modules and external devices. Also it comes with 50 great-sounding factory presets to get you started, plus it offers a huge number of user presets.
fxbox adds new creative possibilities to Eurorack, with its straightforward touch screen interface, high-quality 24-bit audio path, and innovative sound manipulation capabilities.
Features:
16 great effects including Pitch shift, Distortion, Bitcrusher, Filter, Chorus, Phaser, Flanger, Ring Modulator, Freeze, Loop, Reverse, Vinyl, Gate, Panner, Delay, Reverb
24-bit/48kHz stereo input/output with Reverb Wet Send (FX 1/2)
MIDI for timing and effects triggering with Clock for synchronization
Accepts TRS MIDI input compatible with Arturia and other products
Save/Recall patches with microSD
26 HP Eurorack compatible. +12V: 350mA, -12V: 0mA, 5V: 0mA
Pricing and Availability:
$599.95
More information:
www.1010music.com
We've already seen the MPC Live  (see our video) -  the new breed of Akai standalone MPC units, it has a compelling set of features in a relatively affordable package. Now comes the MPC X, which adds a larger touchscreen (10.1"), 16 fully assignable Q-Link controls with OLED displays. More MIDI ports (4 out, 2 in) , and 8 CV/Gate outputs, for direct interfacing into analog control.
You get the same USB host ports,  2GB RAM, 16GB internal storage with 10GB Library, additional eSata dock for more internal storage, 64  stereo voices, with 8 stereo audio tracks.
Product manager Andy Mac, came down to show us what the MPC X can do, and also to give us some more detail on how to switch from MPC Touch mode, where the host computer handles the processing, to stand-alone mode where tracks created using 3rd party plug-ins can be incorporated. Sit back, there's a lot to cover...
MPC X should be arriving shortly after MPC Live (expected any day now). MPC 2.0 will be released with the MPC LIVE.
MPC X £1499/$2199, MPC Live £799/ $1199.
For more information:
Akaipro.com
Gibbon Digital, a brand developed by Buso Audio,  a manufacturer of high end, hand crafted studio furniture has started Kickstarter campaign for their Goliath MIDI controller which they describe as 16 hands in one. Here's what they have to say about it...
The Goliath is a standard MIDI controller. It lets you take control of multiple parameters at once with just one encoder! With the Goliath you can create complex changes to your sound while playing and record complex automation to your DAW by controlling multiple plugin parameters at once. Because it's battery powered, the Goliath is perfect for live performances. The Goliath is a great companion to a synthesizer, modular rig, drum machine or anything with a MIDI input.
Main features
MIDI learn
Standalone operation
Control multiple MIDI CCs at once
MIDI CCs randomization
Random notes generator
Battery powered (9VDC, battery not included)
Made in EU
From 59 Euros. The first batch of 100 units will be ready for shipping in early May.
More information:
Goliath
Retronyms has released Looperverse, which they describe as the ultimate loop recording/performance system for iOS. It's the result of a multi year collaboration between Retronyms and Cycling '74, creators of MAX/MSP. The Looperverse product lineup includes a wireless stomp pedal and an app for iPhone and iPad.
A spokesperson told us, "Looperverse is a unique hybrid of a familiar looper, with some of the most powerful aspects of computer-based multi-track recording and editing. It is a unique combination of always-there immediacy with the ability to powerfully manipulate what you've recorded, right away."
Here's the full story in the developers' own words...
Looperverse merges the classic pedal-based live looping workflow -- utilized by Ed Sheeran, DubFX, DJ Quest, and more -- with powerful multitouch editing features. Including an array of advanced tools, Looperverse makes recording, editing, and customizing loops simple. Continuously record up to 16 tracks worth of content, and immediately edit them. The 16 track loop recorder includes sound-on-sound, overwrite, and next track modes. Musicians can adjust track sends to the built-in delay and reverb effects, as well as adjusting pan, gain, mute, and solo in the mixer. Looperverse features advanced waveform editing, pitch shifting, time stretching, live reverse, extensive undo/redo, and time signature support. These features allow musicians to limitlessly modify their scenes and explore phrases and riffs.
The Looperverse app connects your music to the iOS music ecosystem. Inter App Audio and AudioBus support ensures that you can record any virtual instrument. Looperverse also supports Ableton Link, allowing musicians to lock tempo with Ableton Live or apps on other devices. AudioCopy support allows musicians to quickly publish music on SoundCloud, copy and paste from hundreds of compatible apps, and choose from millions of loops and sounds available in the Content Store.
The app is integrated and enhanced with the Looperverse pedal, which provides 6 premium quality switches pre-mapped to undo, redo, clear, tap tempo, record, and playback. Each setting is fully customizable, so users can remap to their liking. It can be controlled from users' iOS devices and will work as a standalone pedal with any device that supports MIDI. Because the Looperverse pedal supports the Bluetooth (BTLE) MIDI standard, it's compatible with virtually any software on any device. Musicians can control Looperverse from external hardware and remap to their liking with MIDI and MIDI Learn support.
App Features:
Advanced 16 track loop recorder
Time stretching and pitch shifting for scenes, tracks, and segments
Delay and reverb send effects
Built in mixer with pan, gain, mute, and solo
Advanced waveform editing
Snap to grid or transient for extensive editing
Advanced time signature support
Tap tempo
Stem export for DAWs
Reverse songs or musical segments in real time while recording or playing back
Extensive undo/redo
Audio triggered record
Play scene with keyboard
IAA, Audiobus and Ableton Link support
MIDI and MIDI learn support
AudioCopy and AudioPaste support
Pedal Features:
Premium quality powder coated aluminum enclosure
Low latency Bluetooth MIDI interface
Six premium quality steel switches
Pre-mapped and fully customizable
Looperverse is available now in the App Store.
The app retails for $9.99 and works universally with iOS devices.
Looperverse pedals are available for purchase directly on www.retronyms.com for $199.99.
More information:
www.retronyms.com
http://www.sonicstate.com/news/2017/04/05/messe-2017-presonus-studiolive-24-digital-mixerrecorder/
The 24 channel version of the StudioLive Series further improves on the StudioLive's legendary ease of use while letting you customize workflow and operations to fit the way you work.
The new console features 24 physical input channels with touch-sensitive, motorized faders and recallable XMAX Class A preamps.
For more info Visit Presonus
I visited the messe yesterday. Found it to be a lot smaller than 6/7 years ago. Both drums and guitars were in one hall. It is quite easy to visit in one day and see it all.
I was really interested in moddevices. Had a nice chat at the stand. They have just implemented snapshots, because loading a new rig does take some time. I also had a quick playthrough. I think it sound allright. It has a lot of potential, but it is still early days and quite expensive.
I also saw the new Bias chorus pedal:
BluGuitar were doing some great demos:
And outside I found Relish guitars:
That was the guitar related stuff that I found interesting. I really missed Roland/Boss, Fractal Audio, Atomic and Headrush. Also most major guitar and amp brands were not present.
The Musikmesse is a shadow of what it was before. I spent more time at Pro Light and Sound, where most major companies were present.
Quote from: vanceg on March 31, 2017, 01:57:56 PM
Zylia Announces New Mobile Ambisonic Recording Solution
Zylia has introduced a Windows tablet-compatible version of their software for their ZM-1 microphone, giving users a mobile solution for 3rd order Ambisonics recording.
"Field recordings can yield unique audio samples that bring terrific character and richness to a variety of applications," says Tomasz ?ernicki co-founder and chief technology officer of Zylia. "Sound engineers use the ZM-1 for ambient sound recording in the field, and to create spatial soundscapes. Musicians heading to outdoor concerts and jam sessions use the microphone to capture live shows and one-of-a-kind collaborations. Now requiring only the microphone and tripod, a tablet, and headphones, field recording with the ZM-1 is unbelievably simple and convenient."
The ZYLIA ZM-1 is a compact mic, capable of delivering 48-kHz/24-bit resolution while capturing the full spatial sound scene. Boasting 19 MEMS microphones, the spherical array ,together with software, can auto-detect sound sources from around the microphone and capture that sound as separate tracks for further editing on a digital audio workstation.
For details, see the Zylia site.
#23
Quote from: admin on April 06, 2017, 05:51:39 PM
Main features
MIDI learn
Made in EU
More information:
Goliath
I bought me one of these.
https://www.vguitarforums.com/smf/index.php?topic=29390.0
