Mobius Looper - using FC-300
Started by rolandvg99, July 26, 2013, 11:52:07 AM
rolandvg99
Almost bought a RC-300 last week, but got two gigs cancelled and ended up a bit short on cash. My main gripe with the RC-505 is the lack of a sub output. Now I'm back with Mobius and finally took the time needed to learn some scripting. Made a custom floorboard with 8 switches and plugged 6 of those into my FC-300 and two directly to the VG-99. I then gave each controller a fixed midi assignment on the VG-99. USB from VG-99 to my old MacBook, some MidiPipe magic, and I'm in looper heaven. Discrete inputs, multiple outputs and switchable configurations. I use only two loops for what I'm doing so it set the switches up like this:
Button 1 - Track 1 script with record->overdub->play and overdub if pressed again.
Button 2 - Track 1 script with mute - sustained press=reset
Button 3 - Track 2 script with record->overdub->play and overdub if pressed again.
Button 4 - Track 2 script with mute - sustained press=reset
Button 5 - Track 1 script with loop restart for stutter/faked drum breaks
Button 6 - All tracks Stop/Start script
Button 7 - Global mute
Button 8 - Global reset
FC-300 is available at all times for VG-99 usage.
Scripts can be shared if someone is in need...  8)
My little Soundcloud corner
QuoteScripts can be shared if someone is in need...
Please do!
rolandvg99
Ok, scripts attached.
Some more about Mobius scripting can be found here: Mobius Scripting
4 scripts attached in the zip file.
- Record/Overdub/Playback wih sustained undo.
- Custom Mute with reset.
- Retrigger/Stutter
- All play/stop
I assign these to track or group depending on setup.
More interesting stuff about Mobius from this guy: Per Boysen
My pedal board is made using some leftover laminate flooring and a beat up Warwick Rockcase with the bottom inner plate removed.
Grabbing scripts right now!  I have VG-99/FC-300/RC-300 - the rest is a piece of cake!
Beirne
I took a set of midi bass pedals (midipeds I made from a kit for $60 off ebay) and mapped note numbers to Mobius settings.
Easy beezy.
Mobius tends to crash on me though after 30minutes.
But the pedals work great.
www.intangiblesny.com
www.facebook.com/intangiblesband
Hurricane
Quote from: Beirne on February 14, 2017, 02:22:01 PM
Easy beezy.
What OS is crashing ?
