QSC-TouchMix-30 Pro
Started by Elantric, September 29, 2016, 10:16:02 AM
http://www.qsc.com/live-sound/products/touchmix-mixers/touchmix-30-pro/
http://www.qsc.com/resource-files/productresources/mix/30/q_mix_tmix_30_pro_specs_en.pdf
http://www.qsc.com/resource-files/productresources/mix/30/q_mix_tmix_30_2ddrawing.pdf
http://www.americanmusical.com/Item--i-QSC-TOUCHMIX30-LIST
The TouchMix-30 Pro supports Core Audio and is capable of providing audio input and output to most DAW software running on Mac® computers.
And the USB Host port supports third party  USB Class Compliant USB<>MIDI interface cables  - for remote MIDI control
A remarkable, new standard for performance in a compact digital mixer, the QSC TouchMix-30 Pro has the features and functionality that will satisfy the most demanding professional while also providing an intuitive workflow that delivers great results, quickly and easily, to users at every level of experience.
Perfect for production professionals, musicians and bands as well as live performance venues, its 32 mixing channels (24 Mic/Line, 6 Line, Stereo USB) and 16 outputs offer tremendous signal management flexibility for a wide range of applications. But beyond simply offering a higher channel count than its predecessors, a host of additional, new "Pro" features sets TouchMix-30 Pro apart from its smaller siblings:
Large (10-inch) multi-touch touchscreen offers more on-screen information while also providing greater hands-on control
Anti-Feedback and Room Tuning Wizards simplify complex equalization tasks
Two real-time analyzers (RTA) provide instantaneous analysis of channel tonal balance and room response
Touch-and-route patch matrix for easy "multing" and rearrangement of inputs
Eight sub-groups with 6-band full parametric EQ, variable high-pass and low-pass filters and limiter may be linked for stereo
32-channel direct-to-hard drive record/playback - capture and recall performances without the need for an external computer
32-Channel DAW interface with Apple® computers allows for bidirectional I/O with popular workstation software
MP3 playback direct from USB
Additionally, the TouchMix-30 Pro offers even more of what you would expect and demand from a TouchMix Series mixer:
24 class-A microphone preamps deliver pristine, studio-quality audio
Over 120 live Instrument, microphone and other audio source presets created in live environments provide mix-ready channel settings
All outputs feature 1/3 octave graphic equalization and 6-band parametric EQ plus limiters, delay and 12-band notch filters
14 mono mixes may be paired for stereo while two pairs of Auxes can drive wired in-ear monitors (IEM) directly
Six stereo effects processors plus pitch-correct offer studio-grade signal enhancements, without sacrificing Auxes or additional channels
Additional features found on all TouchMix Series mixers also include:
Gain, Effects and Routing Wizards for the ultimate in fast workflow
Simple Mode offers "one knob" control over various processing functions
Advanced Mode provides full access to processing controls for experienced users
4-band full parametric EQ, variable high-pass and low-pass filters on all input channels
Eight DCA and Mute groups
WiFi control via iOS and Android handheld and tablet devices
New Software for TouchMix Series Digital Mixers
Taking small-format mixing to the next level for both professional and novice users alike, QSC is pleased to introduce Version 3.0 for the TouchMix-8 and -16 Series and Version 1.2 for the TouchMix-30 Pro. The new firmware is available as a free download for current users and will be factory-installed in new production units going forward.
Version 3.0 for the TouchMix-8 and 16
Version 3.0 for TouchMix-8 and -16 includes twenty significant enhancements, making these models far and away the most powerful and comprehensive, yet easy-to-use compact mixers available. Many features previously available exclusively on the Series' flagship TouchMix-30 Pro are now implemented, including:
Anti-Feedback Wizard
Room-Tuning Wizard
Real-Time Analyzer (RTA)
Copy-and-Paste,
MP3 playback from USB drive
Input Delay
Output Parametric EQ
15 dB Digital Gain
Channel Overview
USB Drive Formatting
Improved graphics and screen layout
A number of additional, all-new enhancements to the mixer are also provided including:
Channel Safe
Tap Tempo
Tablet Follows Mixer
Additional User Buttons (on connected tablet)
Ability to configure Aux 7/8 and Aux 9/10 as balanced, mono outputs (TouchMix-16).
QSC loudspeaker tunings are also present in Version 3.0, including presets for our new K.2 Series powered loudspeakers.
Version 1.2 for the TouchMIx-30 Pro
Advancing the capabilities of the flagship TouchMix-30 Pro, Version 1.2 provides the all-new features found in the smaller channel-count models along with a number of additional system and operation enhancements.
An update to the TouchMix Control app for iOS and Android devices is also available at those applications' respective app stores.
Release Notes for Firmware Version 1.3.09373
New Features / Improvements (Mixer):
This version adds a gain-sharing Automatic Microphone Mixer (AMM). Automatic Microphone Mixers are most commonly used for speech applications such as conferences, presentations or panel discussions in which there are multiple talkers and multiple microphones. An Auto Mixer will reduce feedback and minimize extraneous noise (such as paper rustling from panelists or HVAC) by allocating gain to microphone channels with active talkers while reducing the gain of unused channels. The TouchMix-30 Automatic Microphone Mixer (Auto Mixer) is a gain sharing design that is available for all 24 mic/line input channels.
Bug Fixes (Mixer)
Fixed a bug that could crash the Ethernet driver and require a hard power cycle if bad data was entered for the gateway IP address.
Fixed a bug that caused the Phones and Monitor buttons to remain dimly lit when mixer is in Standby.
Android App – A recent release of the Chrome browser for Android introduced a change that could cause the Android TouchMix app to crash when meter activity occurs. This has been fixed.
Known Issues
The Automatic Microphone Mixer's Sensitivity Follows Fader function is not documented in the built-in Info System. This will be corrected in a future release. The missing information is as follows.
For some applications it may be desirable for the sensitivity of an Auto Mix channel to vary as the channel fader is moved. For example, an operator may want to bring a talker's level down while his microphone is being repositioned. At the same time, the operator wants to reduce the effect of the microphone handling noise on the other Auto Mixer channels. Sensitivity Follows Fader will function similarly to a post-fader pickoff point but the Auto Mixer will not be affected by channel dynamics and EQ. This eliminates unpredictable interactions between the channel compressor and the Auto Mixer while still allowing the Auto Mixer to respond to changes in channel level. The Auto Mixer sensitivity will also be affected by any DCA assigned to control the channel.
Android only – On some Android tablets, the responsiveness of the RTA may be sluggish.
Android only – When using multiple Android tablets and accessing the EQ screen, a pop-up message will appear indicating that the RTA is currently in use by another device even if no attempt has been made to engage the RTA.
Automatic Notification Text
Adds gain-sharing automatic microphone mixer.
Other fixes for minor issues. See release notes on line for details.
https://www.qsc.com/resources/software-and-firmware/touchmix/
Update Your QSC TouchMix-30 Pro Mixer with v2.0 Firmware!
As the flagship of QSC's TouchMix family, the QSC TouchMix-30 Pro digital mixer is known for delivering high-end performance in a portable package. And with QSC's new firmware v2.0 update, the TouchMix-30 Pro is about to get a whole lot more powerful.
The new firmware v2.0 now further satisfies the needs of the most demanding professionals, with a comprehensive list of QSC's most-requested new feature enhancements, including:
- New Custom Fader Banks function supporting three fader banks assignment, each for eight channels, that are saved as part of a Mixer Scene
- Capability to interface with third-party external control surfaces with motorized faders (QSC has verified operation with iCon Platform M+, Behringer XTouch Compact and PreSonus FaderPort 8 control surfaces)
- 28 New Instruments Presets (Cajon, Accordion, Harmonica, Ukulele, Cello, Clarinet, various Percussions and more)
- CP Series Compact Powered Loudspeakers Presets available directly in the mixer as well as CP8 and CP12 loudspeakers' input gain settings recommendations
Plus, the updated Windows DAW driver will allow for a more robust connection to Windows computers and enable plug-ins to run on Windows DAWs and on Waves MultiRack.
If you've got a TouchMix-30 Pro, download your firmware update at QSC.com. And if you're new to TouchMix, now's the time to invest in your new digital mixer. Only through June 30, purchase a TouchMix-30 Pro at zZounds, and get $200 cash back from QSC!
Release Notes for TouchMix-30 Firmware Version 2.0.11095
In response to user requests, the 2.0 release adds significant new capabilities to the TouchMix-30 Pro.
Support for external control by third-party, motorized-fader control surfaces directly connected to the mixer via MIDI-over-USB.
Support for external control by third-party, motorized-fader control surfaces directly connected to an iOS tablet via MIDI-over-USB.
Adds a new External Faders mode (Menu > External Faders) that displays a channel strip view on screen when used with an external control surface.
Adds three Custom Fader Banks (Menu > Custom Banks) that may be easily configured to include any combination of input, output, FX return, sub-group and DCA group faders.
Improved Solo In Place (SIP) operation. FX returns are no longer affected by SIP.
Additional input channel presets for percussion (cajon, djembe, timbale, percussion toys), electronic drum kit, harmonica, flute, cello, accordion and various Banda instruments. Adjustments were also made to vocal and bass presets.
Added support for CP Series Compact Powered Loudspeakers.
Bug Fixes
Fixed a bug that caused only the left channel of a linked pair to be shown in the Auto-Mixer view.
Fixed a bug that caused channels 19 and 20 to output noise under a specific combination of conditions.
Known Issues
Internal info system has not been updated to reflect the features and improvements described above.
Connection of external control surfaces to Android devices is not supported and there is currently no plan to do so.
Android Only - The Phones button may show as being engaged when it is not.
When multiple tablets are used to control a mixer and Simple Mode is enabled on one of the tablets, it may cause an erratic display of the same function on the other tablets.
After a 3rd party control surface is connected, the mixer may need to be power-cycled before the control surface is recognized.
The mixer does not reconnect to a network after a firmware update. This is normal operation. A notification that a power cycle is required is displayed on the mixer following the update.
https://www.qsc.com/index.php?id=631
TMS-30 Firmware 3.0
With firmware version 3.0, scenes, snapshots and cue lists can be used to store and recall TouchMix-30 Pro mixer settings. Scenes include the entire mixer configuration while Snapshots affect designated channels only. Cue Lists arrange Scenes, Snapshots and audio files into a sequence for recall during a show.
Release Notes for TouchMix-30 Pro Firmware Version 3.0.12379
This release includes major additions to the ability to save, recall and manage settings.
Snapshots save and recall selected settings for designated channels without affecting other mixer settings.
Update provides a shortcut to saving current settings to a scene, snapshot or user preset.
Adds Cue Lists. This feature may be used to select and arrange scenes, snapshots and audio files for recall or playback.
Backup creates and stores an archive that includes all mixer settings, scenes, snapshots, cue lists and user presets.
Save to App supports storage/recall of scenes, snapshots, cue lists and backups to/from a tablet.
Snapshots, scenes and user presets now include an Info field where a description may be entered.
Adds Snapshot and Cue List assignment options to User Buttons.
Improved loading speed for scenes.
Custom Fader Banks now include the option of inserting empty channels when the user wishes to include fewer than eight channels in a bank.
Offline creation and editing of scenes, snapshots and cue lists.
Bug Fixes
Fixed a bug that caused the next/previous function to work improperly when using Custom Fader Banks.
Fixed a bug that caused the faders to be displayed improperly on some iPad models (available from the App Store).
Known Issues
The internal Info screens for 'Menu' and 'Scenes, Snapshots, and Cue Lists' are not provided in any languages other than English.
Release Notes for TouchMix-30 Pro Firmware Version 2.0.11665
This is a maintenance release and does not add any new features or functionality. See below for a list of the bugs we've squashed. Before you install the firmware, remember the first rule of shows...
If you are about to do a show with your gear set up and working don't be changing things. Give yourself time to do the upgrade and get all the mixer's settings squared away.
Bug Fixes (Mixer)
Fixed a bug that could cause the mixer to crash when a very large number of screens have been loaded.
Repaired an issue that could cause the compressor to operate improperly when certain channels are selected as a Side Chain source.
Addressed a bug that could cause Stereo In 27/28 to display the audio level of Stereo In 29/30 when Stereo In 29/30 is selected as a Side Chain source.
Rectified a bug that caused all input channels to be assigned to the Main L/R mix when a Channel Reset was performed on the Main L/R even if the input channels had been unassigned.
Corrected a problem that caused the Compressor on Ch. 20 to become inoperative.
Remedied an issue that could cause Inputs 19 and 20 to send distortion/noise at a high level with a certain combination of settings.
Bug Fixes (iPadOS)
Fixed a problem that could prevent display of the channel name label and gain indication.
Release Notes for TouchMix-30 Firmware Version 2.0.11265
Bug Fixes
Fixed a bug that could cause the master rotary encoder and other controls to become sluggish or unresponsive.
Fixed a bug that can cause Aux mix names and linking to be reset to factory default settings.
Minor corrections to text and labelling.
Bug Fixes
Known Issues
TMS-30 Training
https://training.qsc.com/course/view.php?id=23
