SY-300 - Inside pics of the SY-300
Started by gumtown, February 27, 2016, 03:26:26 PM
I have decided to finally make use of my SY-300 on my pedal board,
initially to replace my preamp pedal, then anything more is a bonus.
To mount it, I removed the 4 corner screws under, and use 4 longer screws to attach right through the pedal board.
While at it, I removed the whole cover plate and took a few snaps.
The internals are quite similar to the GR-55 and GT-100, with the same CPU/DSP.
Chumly
I would have thought by now in a signal level device such as this, that there would not be much need for discrete semiconductors (I assume the little  metallic cans are transistors) but I guess there really is not very many of them as compared to those larger chips (which would contain umpteen millions of devices)...right / wrong?
It also is a crying shame that so much of the electronics manufacturing is no longer North American.
Quote(I assume the little  metallic cans are transistors?)
Actually those are Bulk Electrolytic capacitors  - for a clean power supply and decoupling AC audio signals - not going away anytime soon
learn more here
https://www.vguitarforums.com/smf/index.php?topic=6125.msg124598#msg124598
http://www1.appstate.edu/~curtincm/sculpture/suppliers/gizmos/Practical_Electronics_for_Inventors.pdf
The metallic cans are electrolytic capacitors.
I haven't seen transistors in metallic cans since early 70's although I still have a collection of them, generally of germanium or R.F. silicon type.
Chumly
Ah thank you guys, I learn so much from y'all!
Here's one of mine - designed and built here in USA.
You hear what it sounds like when you see a Movie
www.uslinc.com
Chumly
Chumly
Since it's for digital cinema (I gather?) why the many text references to "auditorium" and why analog inputs / mic inputs? It seems like it's a multi-channel processor / RTA / D-A converter for movie houses?
QuoteIt seems like it's a multi-channel processor / RTA / D-A converter for movie houses?
Bingo
http://www.film-tech.com/warehouse/manuals/Jsd100Manual.pdf
this particular model utilizes both analog and digital formats.
Auditorium is just a more global term  - as these often go into museums or surround sound displays
Analog Mic ins are for calibration RTA room calibration
and some jurisdictions require an emergency paging system in case of fire, etc.
Analog "non-sync" inputs are for the venue to play music between showings
we have other boxes that do more 100% digital
http://www.cinemaparts.com/
http://www.cinemaparts.com/cms-2200-cinema-media-server/
High Frame Rate Cinema Media Server for the Digital Cinema Industry.
Advanced high frame rate media server supports JPEG-2000 decoding of
4K and HFR 2K images with state-of-the-art solid state storage.
Features
Combined IMB with solid state storage
1.5TB, 2TB, or 3TB Solid State Storage
Available ingest with two USB 3.0 or eSATA
JPEG-2000 decoding up to 500 Mb/s
2K 2D 24fps to 60fps
2K 3D 24fps to 60fps
4K 2D 24fps to 30fps
AES-128 decryption/HMAC-SHA1
MPEG-2 decoding up to 120 Mb/s
Two HD-SDI inputs and two HDMI inputs
Dual 1 Gb copper and fiber data ports
Auxiliary control port (RJ45)
Built in automation with optional expansion module
Sixteen channel digital audio
Sync input and output for dual projectors
Civolution image and audio forensic marking
FIPS, DCI, CE and FCC compliant
To some, this might be what the inside of the SY-300 is like.
Circuit board tracks and components are like streets and houses..
Quote from: Chumly on February 27, 2016, 04:40:32 PM
+1. Using the knowledge freely shared on this and other simular forums, the muse finally payed me a visit. :-)
Riggar
Great pics thanks - always interesting to see inside these lovely boxes :D
Shingles
I design electronics that are then built in the UK or the US.
I can't show you them.
I can't tell you what they do.
I can tell you I work for GE Aviation Systems.
Nik
