RC-300 - Advanced Looping Technique
Started by or_sarusi, January 21, 2016, 02:21:05 PM
or_sarusi
hi every body
been wondering if anybody knows\wants to know how to assign 3 different rhythms to 3 different tracks -  just solved it
in single track mode
memory edit>assign(X) rhythm pattern > min + max same pattern(X) > toggle> src > track 1 rec\dub
memory edit>assign(2) rhythm pattern > min + max same pattern(X) > toggle> src > track 1 play
memory edit>assign(3) rhythm pattern > min + max same pattern(y) > toggle> src > track 2 rec\dub
memory edit>assign(4) rhythm pattern > min + max same pattern(y) > toggle> src > track 2 play
etc.
if you have loop sync and tempo sync on it could be great going through rhythms on the same beat.
please comment if you found it useful or not
regards
Or
nunoj
Very useful and great tip
Arnieus
Very Useful
Thank you. I have been trying to accomplish something like this by downloading .WAV drum loops into tracks. Then recording guitar parts over them or just use them for rhythm. If LOOP END is set to immidiate I can stop the track to pause the rhythm. When the WAV file is too loud I set the play level for that track at 50 and record level at 200 trying to balance them. Clunky I know but I couldn't think of any other way. Can't wait to try this.
