Roland SYSTEM-1 VST / AU Software Synthesizer
Started by Elantric, July 09, 2015, 02:07:25 AM
Roland SYSTEM-1 Software Synthesizer Software Synthesizer (4 Voice max Polyphony)
Compatible DAW list and Knowledge Base
http://cdn.roland.com/assets/media/pdf/Compatible%20with%20SYSTEM-1%20Software%20Synthesizer_e01.pdf
PLUGIN VERSION OF THE ACCLAIMED SYSTEM-1
Get all the sonic power and versatility of the acclaimed SYSTEM-1 synthesizer in a VST and AU compatible plugin. Like the SYSTEM-1 hardware, this software version breaks new ground with remarkable flexibility and a vast palette of stunning sounds. It has the bold, unmistakable character associated with Roland synthesizers for over four decades. For SYSTEM-1 hardware owners, the software provides advanced editor/librarian functions and total DAW integration. For in-the-box producers, it delivers the mighty sound of the SYSTEM-1 without the need for hardware.
Maximum Polyphony4 voice
LFOWaveform (SINE, TRIANGLE, SAW, SQUARE, Sample&Hold, Random)
Fade Time
Rate
Pitch Modulation Level
Filter Modulation Level
Amplifier Modulation Level
OscillatorWave Form (SAW, SQUARE, TRIANGLE, SAW 2, SQUARE 2, TRIANGLE 2, NOISE SAW, LOGIC OPERATION, FM, FM+SYNC, VOWEL, CB)
Sub Oscillator (-1 Oct, -2 Oct)
Noise Oscillator (White Noise, Pink Noise)
Range (64, 32, 16, 8, 4, 2)
Color
Fine Tune
Coarse Tune
Oscillator Sync
Cross Modulator
Ring Modulator
Modulation Source (MANUAL, LFO, P. ENV, F. ENV, A. ENV, SUB OSC)
Envelope Attack Time
Envelope Decay Time
Envelope DepthMixerOSC 1
OSC 2
SUB OSC
NOISEFilterLPF Type (-12 dB, -24 dB)
LPF Cutoff
Resonance
HPF Cutoff
Envelope Decay Time
Envelope Sustain Level
Envelope Release Time
Envelope Depth
Key Follow Amplifier
Envelope Decay Time
EffectTone
Crusher
Reverb
Delay
Delay Time
Arpeggio
Arpeggio Switch
Arpeggio Type (1 Oct Up, 1 Oct U+D, 1 Oct Down, 2 Oct Down, 2 Oct U+D, 2 Oct Up)
Arpeggio Step (1/4, 1/8, 1/16, 1/4T, 1/8T, 1/16T)ScatterType (1–10)
Depth (1–10)Tune430–450 Hz
ControllerVolume
Portamento
Legato switch
Bend Range
Tempo Sync switch
LFO Key Trigger switch
Key Assign Mode switch
Key Hold switch
Octave (-3, -2, -1, 0, 1, 2, 3)Sampling Frequency44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz, 176.4 kHz, 192 kHzPatches per bank64 patches
*User can make new user banks.Plug-In FormatsVSTi 2.4 (32 bits, 64 bits) * Windows only
VSTi 3.6 (32 bits, 64 bits)
AUSYSTEM REQUIREMENTSMac OSOperating System:
Mac OS X 10.8.5 or later
Host Application:
VST instruments (VSTi) version: VST 3.6 compatible
Audio Units (AU) version: V2 Audio Units compatible
CPU:
Intel® Core™ 2 Duo or better
RAM:
4 GB or more
Hard Disk:
100 MB or more
Display resolution and Colors:
1280 x 800 dots or higher, 16.7 million colors or more
Other:
You'll need Internet connectivity to activate this software.
You'll need installation SYSTEM-1 driver to connect this software to the SYSTEM-1.WindowsOperating System:
Microsoft® Windows® 7 SP1
Microsoft® Windows® 8/8.1
* This does not work with the Windows® RT.
* This does not work with the Windows® Phone.
* This does not work on the virtual machines such as Hyper-V, Virtual PC, or Boot Camp.
Host Application:
VST instruments (VSTi) version: VST 2.4/3.6 compatible
CPU:
RAM:
2 GB or more
Hard Disk:
100 MB or more
1280 x 800 dots or higher, 24 bits Full Color or more
Other:
You'll need Adobe Reader (available free of charge) in order to read the online help.
Download the Demo
http://www.roland.com/products/system-1_software_synthesizer/downloads/
