GR-55 - dreamy atmospheric drop d
Started by nervoteso, October 24, 2014, 06:45:31 PM
nervoteso
 just done a drop e patch with multi control (to have gs1 and gs2 working as changing presets again i've set it every time, is it the only way?):
if you push exp you've cello and strings
if you lift exp just nylon mod with delay and full range amp
press ctl to add distorted amp (mfx) and have strato instead nylon mod
press gs1 to add long reverb
press gs2 to add flanger
if you press exp sw you've jazz drums instead cello (on 6th 5th and 4th string)
