Boss GP-10 - Owners Manual/ Parameter Guide/ Control Assigns / Signal Flow
Started by Elantric, June 20, 2014, 04:57:08 AM
http://lib.roland.co.jp/support/en/manuals/res/63181352/GP-10_e02_W.pdf
Boss GP-10 - Parameter Guide
https://static.roland.com/assets/media/pdf/GP-10_Parameter_Guide_e02_W.pdf
Boss GP-10 Signal Flow
Boss GP-10 USB Routing
Boss GP-10 - Control Function List List
Boss GP-10 - Control Assign Target List
Boss GP-10 Alternate tuning Types
GP-10 GR-300 Controls
GP-10 Dual OSC Controls
GP-10 Poly FX Controls
Boss Tone Studio when connected to Internet has a built in messaging system, and tonight it reported that an Updated GP-10 Owners Manual (released July,16,2014) is available
See attached
(GP-10_help_e-01_W.pdf
Upon review, its simply the existing GP-10 Owners Manual, GP-10 Parameter Guide, and GP-10 Sound List - but all merged into one 33 page PDF file.
If you want to obtain more incite and better explanations of how Roland gear works - review the OWNERS MANUALS for the earliest examples of current gear.
http://www.gitaar.net/forum/index.php/file/7/14419/20030641-Boss-GT-x-Set-Up-v02.pdf
http://www.bossus.com/support/knowledge_base/207166693
SY-300: GETTING STARTED WITH BOSS TONE STUDIO
Please follow these steps to download and import new patches into your SY-300. If you have already done some of these steps, skip to the one's that you haven't done yet and continue from there:
1. Install the SY-300's USB driver.
    You can get it here:
    http://www.bossus.com/support/by_product/sy-300/updates_drivers/
2. Plug a USB cable into the SY-300, with the end going to your one of your
    computer's on-board USB ports, preferably plugged into a USB 2.0 port, or a USB
    3.0 port that is backwards compatible with USB 2.0 devices.
    (Check your computer's technical documentation if you're not sure)
3. Install the BOSS Tone Studio application.
    (which will also install the required  Adobe AIR Application Runtime environment resources for your OS)
4. With your SY-300 plugged in and turned on, launch the BOSS Tone Studio
   application. If you need to download and install it, you can get it via the link
   provided above.
5. Click the TONE CENTRAL button, located in the lower left-hand corner of the
    program, then choose the Genre you want.
6. Under the column heading that says: LIVESET, select which Preset Collection
    you wish to import into your SY-300.
7. Once you've selected your choice, click the: ADD button at the bottom right
    of the screen.
8. Click the: LIBRARIAN button.
9. Drag and Drop all presets over the left-most column (SY-300's Factory
    Preset library) you wish to save to your SY-300.
SY-300: BYPASS OSCILLATOR WITH AN EXTERNAL FOOTSWITCH
It's sometimes useful to be able to bypass one or more of the SY-300's three oscillators using a footswitch assignment, instead of having to perform multiple button presses in the middle of a performance. Recommended footswitches include the BOSS FS-6 or FS-7 models.
Here's how to do this:
1. Connect the A&B output jack of a an FS-6 or FS-7 to the EXP/CTL 4,5 jack on the
    back of the SY-300, using a TRS to TRS 1/4" cable.
2. Press MENU.
3. Turn SELECT knob to select CTL/EXP.
4. Press SELECT knob.
5. Turn SELECT knob to select CTL 4.
6. Press SELECT twice.
7. Turn the second Parameter knob from the left to turn on the assignment.
8. Turn the third Parameter knob from the right to choose: MANUAL.
9. Turn SELECT knob to go to Page 2.
10. Confirm that TARGET CATEGRY is set to: OSC1 WAVE, if not turn the SELECT
      knob until: OSC1 WAVE is selected.
11. Confirm that TARGET is set to: OSC OFF/ON, if not turn the SELECT
      knob until: OSC1 OSC OFF/ON is selected.
12. Turn SELECT knob to go to Page 3.
13. Turn the first Parameter knob from the left to choose: MOMENT.
14. Repeat these steps for oscillators two and three if desired.
