Katana Head plugged in 220v. Turns on, no sound.
Started by MeAndMyGuitarStuff, September 25, 2017, 01:28:17 PM
MeAndMyGuitarStuff
So yes, I did that. Is it something that would burn only one part that I could replace myself or does it need a full diagnostic?
The appropriate AC Mains voltage rating should be indicated on the rear of the Katana Amp, as well as the Katana packing box for your region
If you purchased locally - contact your local Boss Distributor for service.
QuoteSo yes, I did that. Is it something that would burn only one part that I could replace myself or does it need a full diagnostic?
Its likely many items were damaged  -  Power Transformer
vtgearhead
Oh, ouch...  You could be as lucky as a blown primary fuse or as unlucky as massive circuit damage.  Or, anywhere in between.
MeAndMyGuitarStuff
Mortyworld
Any update? Same thing happened on my Katana 100 head.
Headphones is working fine but no sound on speaker out.
Quote from: Mortyworld on March 07, 2021, 09:09:03 AM
Seek local Boss Service center
