Test CPU Performance vs. Real-Time Performance in DAW
Started by bbob, June 22, 2017, 02:45:09 PM
bbob
Very informative video I came across today explaining that your PC's CPU often isn't the culprit when audio pops, clicks and dropouts occur.
Thanks for sharing. Great info
Vade
Here's the download page for LatencyMon 6.51 - mentioned in the video - which works on Windows 10.
http://www.resplendence.com/downloads
https://soundcloud.com/vadie
https://www.passmark.com/products/soundcheck.htm - Free
SoundCheck - Test your PC soundcard, speakers and microphones
PassMark SoundCheck™
Download now! (871 KB)
Add SoundCheck to cart
Versions:
V3.0 (Build 1003)
Latest release date:
10 May 2012.
Price:
Free for personal use. Company license is US$24.00 per license.
(See sales page for more pricing details)
Platforms:
Windows XP, Vista, Windows 7, 8 & 10
Requirements:
32 MB RAM, 3 MB of disk space.
Optional SoundCheck hardware accessories:
PassMark audio loopback cables
PassMark SoundCheck™ is a Windows based application that allows users to test their PC sound card, speakers and microphone. Verify that your sound card can record and playback sounds at various audio sample rates. Check the capability of your speakers to reproduce the highest and lowest frequencies (and your capability to hear these frequencies). Create perfectly formed test tones and loop them back into your sound card to look for distortion using PassMark audio loopback cables. SoundCheck also provides an audio FX test and a surround sound test to analyse those advanced sound card features.
Click for a larger image
Stereo or mono sound can be recorded and played back at a variety of sample rates and resolutions. SoundCheck includes a built-in tone generator that allows test tones to be generated at a selected frequency and sampling rate. This can be done using waveforms such as sine waves, saw tooth waves, white noise, and square waves. The waveform can be plotted and frequency spectrum graphed in real time using fast Fourier transform algorithms.
Test the range of your speakers and hearing
Simultaneous sound recording a playback (with full duplex sound cards)
A comprehensive help file.
Real time waveform display (like an oscilloscope)
Real time sprectum display using fast Fourier transforms
Adjustable frame rate for slower PCs
Selectable sample rates from 5000Hz to 128,000Hz
Stereo and mono recording a playback
8, 16 and 24bit recording and playback
Input and output data rate measurement
Source device selection when multiple sound devices are installed
Test tone generation at any frequency and amplitude
Tone generation using sine waves, square waves, saw tooth waves, spikes and white noise.
SoundCheck generates perfectly formed synthetic waves using the tone generation (rather than playing back recorded wave files)
Compatibility
While all Windows plug and play sound cards (Crystal, Yamaha, Creative sound blaster, ESS, etc..) are compatible, not all sound cards will support the full range of sample rates. Also, not all PC's will have the speed to support a real time display when high sample rates are used. In this case the display Frame rate may need to be lowered.
Important note: Please make sure your mixer settings are correct before trying to record with SoundCheck. See the included help file for details on how to do this. If they are not correct you will get a silent recording.
What's New in V3.0
24-bit recording/playback support.
Spectrum graph now uses a decibel scale for intensity.
Trigger functionality added to waveform graph.
Text overlay on graph has had a color change to make it easier to read
New option to generate pink noise.
Ability to save recordings to wave files
Ability to save generated tones to wave files
Vaultnaemsae
Vaultnaemsae's SoundCloud:
