Mounting GK-3 to a Semi-Hollow body guitar
Started by 47Flyer, August 05, 2016, 08:20:14 AM
47Flyer
I have a couple of nice semi-hollow body guitars that I wanted to mount a GK-3 onto.  The problem on both of the guitars is that there is not enough room between the bridge and the bridge pickup to apply the GK-3 pickup.  How terrible would it be if I mount the GK-3 on the other side of the bridge pickup, closer to the neck but as close as possible to the bridge pickup?  I know that the GK-3 is supposed to be as close to the bridge as possible and I've never seen one mounted the way that I suggested but I don't see any other way of mounting it without removing the bridge pickup.  Thanks.
I guess if that is the only option, then so be it.
Or you could consider making a custom pickup mounting bracket where the pickup is turned upside-down over the strings at the bridge.
QuoteThe problem on both of the guitars is that there is not enough room between the bridge and the bridge pickup to apply the GK-3 pickup
I find on most guitars like that its easy to unscrew the 4 PU mounting ring screws and "slide" the Bridge PU 1/8 inch further away from the bridge to make room for the Mag hex PU . I had to do this with Godin xtSA - it was a simple mod and required no major wood cutting  - thanks to the liberal oversize bridge PU body route.
QuoteHow terrible would it be if I mount the GK-3 on the other side of the bridge pickup, closer to the neck but as close as possible to the bridge pickup?
If you never bend strings  - it might work, but with a "mid mounted GK-3", as soon as you start playing blues licks and bending strings, then the "B string typically drifts away from the GK-3 B string PU pole piece and drops volume, until it  lands over  the GK-3 G string PU pole and that can be problematic with poor results if you use DSP Alt Tunings or Guitar to MIDI  - I dont recommend it.
imerkat
I managed to add one to my semi on a pinch with double sided outdoor mounting tape.
47Flyer
Thanks for the ideas.  I'm going to have to take another look at it.  I just need a few more millimeters so I might use Elantric's idea of sliding the bridge pick up slightly forward.  Otherwise, that custom pickup mounting adapter might work too.
