GP-10 - Adapt Boss GP-10 to work with 5 pin DIN MIDI gear
Started by wackyjacky, September 10, 2015, 07:23:22 AM
wackyjacky
Hello, maybe this has already been discussed but - if I want to conect the GP-10 to a stand-alone sound module - how would I do this? The USB cable is type B male at the GP-10 end but type A male at the other - but most sound modules have a type B (female) port - or is there another solution - would a simple USB A Female to B Male Adapter work?
                                      Thanks for any help/advice
You add the missing 5 pin MIDI I/O like this:
A: Get a Raspberry Pi single board computer + USB MIDI Cable
https://www.vguitarforums.com/smf/index.php?topic=11998.0
or
B: Order the Promova MIDX-10 due to ship soon from Codesmart here
https://www.vguitarforums.com/smf/index.php?topic=15758.0
Or
C: Use a WIndows PC and MIDI Yoke app or Mac with OSX Audio MIDI Manager and a USB MIDI Cable.
jshortz
Probably been discussed before.
Any way to get the Rocktron to switch patches on the GP-10?
Need a third party USB Host to MIDI converter that is compatible with Boss GP-10
I know of two
* PrimovaSound MIDX-10
https://www.vguitarforums.com/smf/index.php?topic=15758.msg121060#msg121060
* Raspberry pi Single board computer+ USB <> MIDI cable
as mentioned in the
Boss GP-10 FAQ
https://www.vguitarforums.com/smf/index.php?topic=11796.msg85343#msg85343
Next typical question is  -
Why cant i just use a MIDI Foot controller with a USB connection?
Because all MIDi foot controllers I know ( as well as the Boss GP-10)  are USB Client (EndPoint) devices
Requires One device to act as USB HOST Device - and those are typically computers
http://electronics.stackexchange.com/questions/49140/what-exactly-are-the-difference-between-a-usb-host-and-device
The host initiates all communication on the bus, the device only responds when asked by the host. For Details see the specs on usb.org.
http://www.usb.org/developers/docs/devclass_docs/
