GR-55 - Switch between 2 tones...?
Started by jipegonzo, October 04, 2017, 07:30:20 AM
jipegonzo
hi there !
is it possible to switch from 1st tone to 2nd tone with expression pedal , i don't find how it works.. :o(
thank you by advance for reply
jp (from france)
read
GR-55 F.A.Q.
* GR-55 Ultimate Multi Control patches (solves the GR-55 long Patch change delay (with mute) issue)
and
Jim Williams Multiple Assignment Patches.
https://www.vguitarforums.com/smf/index.php?topic=5647.msg38806#msg38806
Learn multi-assignments by following all steps outlined here - then edit to suit YOUR needs.
Guitarplayer_10's  GR-55 Ultimate Multi Control patch step by step
https://www.vguitarforums.com/smf/index.php?topic=7267.msg50612#msg50612
GR-55 - Use all four GR-55 tone sources mixed via Expression Pedal position
https://www.vguitarforums.com/smf/index.php?topic=9591.msg151708#msg151708
jipegonzo
