Spicetone Hex fuzz with hex pickup
Started by spicetone, October 08, 2014, 07:26:51 AM
spicetone
An analog multichannel fuzz recording using hexaphonic pickups (13pin output) and 6Appeal Roland GK compatible effect pedal:
https://www.vguitarforums.com/smf/index.php?topic=12104.0
The synthy sound comes from Spicetone's 6Appeal hexaphonic distortion, routed to DAW and synced to a drum track with MIDI from computer.
The song: courtesy of Fairlights (Enda Bates)
www.fairlights.net
www.endabates.net
Gear List
Godin LGX electric guitar with RMC piezo-style hexaphonic pickup
Spicetone 6Appeal (breakout box mode)
Motu Ultralite multichannel soundcard
UAD Stereo Reverb + Delay plugins
Time Freezer VST plugin
Description
The track uses three presets on the 6Appeal. The first one is a fairly full-on distortion setting with the Gain and Tone turned up full. The strings are panned across the stereo field with the low strings quite central, and the two middle strings panned about halfway left and right. The melody is played solely on the top two strings which are hard-panned left and right to give the impression of two distinct melodic lines, with a rhythmic backing from the other, more centrally panned strings.
The rhythmic pulsing in the opening is created by tapping the back of the guitar neck with the right hand while holding a chord with the left. In the first half of the track, the melody is played on the top two strings using hammer-ons and pull-offs (as the picking hand is occupied tapping the neck).
In the second half of the tune a new, modified version of the initial preset is used. This has a tremolo effect on the lower three strings which mimics the tapped pulsing effect from earlier but using modulation, which now frees up the right hand for strumming and picking. This was done using LFO2 which is tempo-synced to the drum machine track using MIDI clock from the DAW.
Finally, the end section just uses a clean preset with the same stereo spread. Apart from the 6Appeal, the only other effects are simple things like some stereo delay and reverb. The one exception is the Time Freezer plugin (which is very similar to the EHX Freezer pedal), thats used to create a sustained drone from the top three strings towards the end of the track. No amps or amp modelling was used.
MusicOverGear
Wow that is very cool piece of gear. Congrats on your great design and execution.
I would love to hear some demos in some styles more familiar to me. That would help me evaluate whether this gear would be useful for my style of playing. E.g. Pop, R&B, Alternative Rock, Country, Jazz, Blues, etc.
Quote. That would help me evaluate whether this gear would be useful for my style of playing. E.g. Pop, R&B, Alternative Rock, Country, Jazz, Blues, etc.
Check your inbox
Read MusicOverGear's Review here:
SpiceTone 6APPEAL: Hex Fuzz, poly Tremolo/Pan, Break Out Box, MIDI Controller
https://www.vguitarforums.com/smf/index.php?topic=12104.msg91906#msg91906
