function Midi controller in GR-55?
Started by looper, March 03, 2014, 04:26:36 AM
looper
Hi,
Would enable the function Midi controller in GR-55, regardless of the patch?
I want to control an app on ipad via usb, but I will be using several patches during the song.
How do? thank you
QuoteI want to control an app on ipad via usb
in order to control IOS apps with GR-55, you must use a separate MIDI adapter cable + Apple USB Camera Adapter
Many are listed here
And read:
*GR-55 Control Assignments
https://www.vguitarforums.com/smf/index.php?topic=10677.0
Also in order to control IOS apps with GR-55, you must use a separate MIDI adapter cable + Apple USB Camera Adapter
looper
Quote from: Elantric on March 03, 2014, 06:01:33 AM
yes, I already have it. just need to learn how to configure correctly.
Thank you.
All info you seek is here
Is the GR-55 USB midi able to work on the iPad/CCK without a driver?
or would a class compliant (driverless) USB/midi (via GR-55 5 pin din midi ) device be better?
QuoteIs the GR-55 USB midi able to work on the iPad/CCK without a driver?
Not that i'm aware of.
I understand the GR-55 connects via 5pin DIN MIDI I/O to the preferred 5pin MIDI I/O interface.
At the link below is a list of typical USB Class compliant MIDI I/O cables that work for me - These work fine for me on my iPad+ Apple USB Camera Connection Adapter
