VG-8EX - New user with a couple of questions
Started by willframecdnvg8, November 11, 2015, 04:55:06 PM
willframecdnvg8
Hi and greetings from Canada. So......I'm now the proud owner of a VG8EX which is being fed by a Frameworks nylon string/RMC pickup with a  Polydrive 11 preamp guitar.I play mostly jazz/jazz blues style .  So far I'm loving the sonic landscape possibilities.
I have been through the manual and the online resources and have learned a lot but still have a couple of questions and would appreciate anyone taking the time to answer.
Lets say I have found a rhythm/comping/chord playing patch that I like for a particular song but want a different patch for solo/lead  work in the same song with a single click to go back and forth between them. The only solution I can see is to have the two patches in a user bank as either X1/X2/X3 or X4 so the foot activated switches handle the change. Is there a better/other way to handle this?
I'm also have trouble sorting out how to get patches available online  loaded into my VG8EX - I have a Roland M512E memory card so would load them there . I believe I need a library Editor on my computer connected to a midi interface which then connects to the VG8EX - which Library Editor and which midi interface are people using today that works ??
cheers for any help you care to share
Will
Quote from: willframecdnvg8 on November 11, 2015, 04:55:06 PM
Will
For changing patches your on the right track , it's the easiest solution and you can also use the Switch buttons on the guitar.
For saving and uploading patches I used Sysex Librarian for Mac I think there's an pc version as well
Works really well , and a Sysex dump and load from a daw such as Cubase etc etc, I've been using midisport Maudio
Good luck
willframecdnvg8
Many thanks for the info it is appreciated and helped a lot - cheers
