VG-99 - Aggregate Audio Device in OS X
Started by arkieboy, August 11, 2012, 04:05:58 PM
arkieboy
Hi all
Looking at making the jump from my 88 to a 99.
For several of our songs we use backing tracks: I use a VS1824 to send a mix with a click to the drummer and a mix without the click to the front of house.
If I used my Macbook Pro with a VG99 and set up a composite driver, Logic Mainstage could see both the VG and its headphone output and I could send the click down the headphone output to Tim while having the main mix go FoH from the VG.
I'm told this works fine with good audio drivers and can hang with bad ones.  Has anyone any experience setting up composite audio drivers with the VG99 in OSX?
Steve
Correct - this should work - although I have not actually tried it.
Report your results
