VG-99 - Old Tape Parallel FX
Started by rolandvg99, June 11, 2013, 12:41:14 AM
rolandvg99
Made a new version of the Old Tape patch using parallel FX. Some precautions must be taken to get this to work. Switch System-Output-Output Mode to Patch before making the following connections. Use Sub Outputs for your Amp/Line output, set Global-Main Output Select to Line/Phone, patch an instrument cable from Main Out L(Mono) to Guitar Input.
F1 selects Guitars
F2 is assigned but not used (automated)
F3 is preamp gain
F6 is Channel B/Spring Reverb volume
FC-300 EXP1 is Wah control
FC-300 EXP1 SW is Wah on/off
FC-300 EXP2 is guitar volume knob
FC-300 CTL1 turns preamp solo on/off
VG CTL1 turns Tape echo on/off
Demo using a Classic ST: Old Tape Parallel FX
Demo using a L4: Old Tape in the style of Jack White
My little Soundcloud corner
