FC300 to beam T-Arm, any help?
Started by foolevil, September 17, 2008, 09:52:23 AM
foolevil
Cant get it working.
It just dont do it.
I can get freeze working ok but T-Arm no!
Any help!
WROOM!
baranger1
Easy fix.
use EXP 1 or 2
1. set target parameter to Dbeam-T-arm -SW
2.Then use the page button on the right and move to the second target parameter for that pedal.
Set that one for D Beam, T-ARM (S/B/F),down min.
Your problem is you need to set the pedal to turn the effect on as well as to tell it to shift pitch.
Its a two switch operation.
Bill
