connecting GR55 through HD500x
Started by ddavewoods, September 20, 2015, 04:38:17 PM
ddavewoods
Hi All
I only have a small room for my setup and its getting cluttered with wires everywhere, so I need to cut out as much as possible, what is the best way to connect my GR55 into my HD500x so as to use it as a through to the AMP.
actually any experiences regarding connecting these two units would be appreciated.
cheers
Dave
imerkat
use the Guitar Out of the GR-55 to the input IN of the HD. If you are not mixing the patches of both devises you can used a 1/4" TRS cable to connect the headphone out from the GR-55 to the Aux In of the HD. If you want to experiment you could connect it through the FX LOOP and add fx to the GR patches.
ddavewoods
Thanks,  can get the guitar out from g to HD guitar in to work, but cant get the effects loop working
