Boucle midi, midi loop in Logic Pro ?
Started by doha1696, December 22, 2012, 08:10:28 AM
doha1696
Hello, impossible to use soft synths with the VG99, I play a few seconds and then, the sound plays alone... I'm on Logic Pro 9 using Omnisphere... In french I think it's called "boucle midi". I'm using USB Connection between my Mac Book Pro and the VG99...
Any ideas ?
Dominik Hardy
http://fret-time.com
is it the same with other apps like garageband and with an other soft synth ??
and I got the translation to mean like a midi loop , correct ?
if so logic is sending back midi to the vg and the vg sends it back to logic
so you have to set midi through/out off in logic
and/or maybe there's a setting in the vg for midi in/through that might have to be set to off
I don't know which i never had to change either logic or the vg , it just worx
doha1696
Thanks for the translation... Your explanations are good but do you know where you can have the midi thru off in Logic ?
Dominik Hardy
under preferences midi
or under file project setting general midi ( there's a box and a scroll window you can tick for no midi through for instruments
