GT-1 in FX return how to use it?
Started by pelaomedinaese, September 14, 2017, 10:13:31 AM
pelaomedinaese
hello guys i'm new here and i don't know if connect my boss in the return of my amp, i've done it and the volume is too loud i can't play, is the amp bad or the return is like that. And for the last question : it obligatory select amp return in the output? thanks for read this thread
pelaomedinaese
is an homebrand from my country (argentina) and basically is a cheap amp
pelaomedinaese
slooky
Maybe turn down your output on the GT_1
pelaomedinaese
Quote from: slooky on September 14, 2017, 01:51:45 PM
yes, i did that but it's so loud that i have to turn the global level 1 and if i down the patch level it only will work for one not for the others
My GT-1 will mute if its  Volume is turned down
Might try inserting a volume pedal to act as a signal attenuator between the GT-1 output and the Amp FX return
