BTS and Master & System settings
Started by shawnb, August 20, 2017, 02:14:19 PM
I have never been able to get BTS to store certain settings, e.g., exp/ctl preferences or output select.  I must always do those on the GT-1 itself.  I think this affects all 'master' and 'system' settings.  Win7, 64-bit.
E.g., trying to set Ctl-3 to be tap tempo, & getting that to be a SYSTEM level setting (not patch).  Can't do it in BTS, must do it on the GT-1 itself.  Also, setting Output Select to Combo.
Is it just me?  Is there a trick?
Blacque Jacque Schellacque
I've had similar experiences when I started using BTS and my GT-1. There where some global settings that just didn't stick when changing them through BTS (I can't remember which ones as I write this) and I had to change them on the GT-1. I wondered then if there was a way to report BTS bugs to Boss. But since these settings are rarely changed and editing patches, which is what I do 99% of the time, works well, I quickly forgot about it.
Personally, I don't know of a way to fix this.
