GT-1 - Gumtown's GT-1 FX Floorboard
Started by gumtown, May 02, 2017, 02:08:50 PM
EDIT:
For those who want to skip straight to the chase,
here is
GT-1FxFloorBoard
https://sourceforge.net/projects/fxfloorboard/files/GT-1FxFloorBoard/
I was having a quick squizz through the GT-1 amps and OD/DS types,
and noticed the Custom Amp and Custom OD/DS are not there.
Nor are 10 effects each in FX1 and FX2 that the GT-100/001 has.
Perhaps these might be accessible like with the Katana ??
Fx FloorBoard Features
Software which emulates the GT user interface in a graphical way.
Does realtime editing of settings from your desktop - saving your back.
Save your valuable GT data, system and custom settings to file.
Patch text view of all your patch settings, and print or save text list to file.
Edit a single effect setting for groups of User patches in one operation.
QuoteI was having a quick squizz through the GT-1 amps and OD/DS types,
I'm hoping this is true!
CodeSmart
I'm sure some guy sitting in a control room at a power utility with some time at hand will have to check it up, otherwise he won't sleep properly  ;D
Quote from: CodeSmart on May 02, 2017, 04:30:31 PM
Ok sure enough, I had a spare hour to conjure this up...
For all those GT-1 users who have always wondered if the GT-1 possesses the same "Sneaky features" like the Katana, here it is.
a reincarnation of the GT-100 editor, modified to shower the GT-1 with GT-100 command parameters in GT-1 type speak.
a windows version for a start anyway..
https://sourceforge.net/projects/fxfloorboard/files/experimental/GT-1FxFloorBoard_Setup.exe/download
CodeSmart
Fantastic and amazing!
No time to try today but I'm hoping for the weekend.
I met up again with my hometown teenage band from 35 years ago and my GT-1 will be handy as a reunion mini rig  :D
aliendough
Gumtown, I'm on a Mac so can't see the editor yet, but how does this work?  Are those hidden Amps in there already, or is your editor doing something else?
QuoteGumtown, I'm on a Mac so can't see the editor yet, but how does this work?  Are those hidden Amps in there already, or is your editor doing something else?
Read the Help to get you in the ballpark
the Help file that gets installed is based upon the GR-55  - so there is much info in the Katana FX Floorboard HELP file that is not applicable to the katana
The GT-1 actually has all the GT-100 amps, so there are no extra 'sneaky' ones  except for the "custom" amps and 6 extra amp parameters.
other stuff to check is the OD/DS custom types too.
For both GT-1 and Katana ,  I'm hoping the Control Assign area can be expanded to support MIDI CC as Sources
BuleriaChk
#9
I downloaded and installed Foorboard GT-1, but am getting "bad data" when it tries to do upload.  The GT-1 is connected and selected as midi device.  Version is 1.07, and Tone Studio works correctly....
I get "Error - System data was not transferred", and then Floorboard comes up with "bad data" in all the slots..
Is there a switch I'm missing?
Update: It is connected; I hit "auto sync" and the GT-1 is messaging "Bulk Data Sending..."  Is that encouraging?  Is it sending everything?  How long does it take?
So...
Has anyone tried the software, and found any extra features not accessible from the gT-1 or Tone Studio interface?
Custom amps or Custom OD/DS maybe?
pelaomedinaese
#11
i have an issue with this software my GT-1 cannot transfer the system data to edit my ptches in the mentioned software, that a the only thing that i can do is open a patch exported from bts but i can't open the rest... i hope that you read this
pelaomedinaese
you are right, i was using the gt 100 version, sorry  ;D
pelaomedinaese
There was an experimental GT-1FxFloorBoard I posted a few months back
for experimental users to try and find any hidden "sneaky" GT-100 features within the GT-1.
Much interest was posted in creating a software to probe the GT-1,
but after it was built and uploaded,
no one replied as to what was found (as I don't have a GT-1 to find out myself), so I recently deleted it.
Blacque Jacque Schellacque
Quote from: gumtown on September 13, 2017, 01:20:15 PM
Hi Gumtown, I got myself a GT-1 at the beggining of the summer. If your intention was to create a GT-1 FxFloorBoard at some point and needed some help, I can give a hand. I didn't know until now that there was a version of your application for the GT-1. I am a software developer so I can certainly do some testing and report any findings. If I know what feedback you are looking for.
I did some quick research this summer by looking at the exported livesets of the GT-100 and the GT-1. You must already be aware that these are in json format, easily readable using an editor that understands json and can reformat it. I used notepad++ with the json plugin. I did edit a GT-1 patch in a liveset trying to enable some effects/parameters/functionnality found in the GT-100 and see if they would magically appear in my GT-1. Result? No luck at all for now.
I don't know if the only intended use of the FxFloorBoard is to access undocumented features of the GTs it supports. If not, it certainly would be nice to see the GT-1 in its list of supported devices.
Let me know if I can help.
BJS
DML
Typical Roland / Boss. At first glance the GT-1 looks like it has the same software, options and possibilities as the GT-001 and GT-100.
But it's not the same. Dealbreaker for me is the absence of the parameter Direct Signal in the speaker sim. That was a dealbreaker with the GR-55 too. All my gain-sounds consist of more or less 15% Direct Signal but that's impossible with the GT-1. What a pitty.......
Boss GT-1000core, Gibson Explorer 2018, Höfner travel guitar, 4x Framus Renegade Pro, Framus Panthera, Framus Panthera Custom 7, G&L Asat, Rocktron/Egnater Velocity Valve, 2x Mesa Thiele EVM12L, 2x Mesa Thiele EVM12L Road Ready, Voes MX12 midi controller, Ovation 2078TX-5 Elite, PJB Cub II - AG150.
hsuru4u
gumtown...which file is the one for the gt-1? floorboard gt-1?
Quote from: hsuru4u on October 24, 2017, 10:36:25 PM
It was only a work in progress and never completed - so its been removed for now
Gumtown wrote>
QuoteThere was an experimental GT-1FxFloorBoard I posted a few months back
Edit : GT-1 editor is finally released
hsuru4u
awwww.i love the layout of the floorboard.
pelaomedinaese
any plans to release fx floorboard for gt-1?
Quote from: pelaomedinaese on December 05, 2017, 07:47:09 PM
The short simple answer is No.
I have no desire to buy a new GT-1 at this stage.
Juuichi
Quote from:  Elantric
the original version Gumtown posted was simply a non working work in progress, with no functionality
After we reviewed the GT-1 DSP code, we determined there were no lurking "sneaky amps" inside the GT-1 DSP
All GT-1 DSP settings  / configs / FX settings can already be edited using the official Boss Tone Studio for GT-1 - therefore there is no need for an independent version from Gumtown
True.... except Gumtowns version looks so since graphically!
Quote from: Blacque Jacque Schellacque on December 08, 2017, 11:27:34 AM
But with Gumtowns busy schedule, and AND LACK OF USERS FUNDING HIS SHAREWARE EDITOR CREATION EFFORTS   - its not worth his time.
