GT1 Wishlist options
Started by Synthetica, December 13, 2016, 07:00:13 AM
Synthetica
One thing that could have been done fairly easy i would think would be to Hold down Crtl-1, or Enter, (or another button) and Press a stomp box/EFX on off button button to implement favorite presets switching rather then the sequential way we do it now.
On the GT-001 the 4 buttons allowed you select favorite presets but do nothing else which is the opposite of the GT1, I always felt this could have also been used to turn on/off Effects.This always bothered me. I would like the opposite of this on the GT1.
Anyone have a direct line to boss to suggest such a thing?
Thanks to my enthusiasm for Katana, Im meeting with head of Roland /Boss guitar products  Yoshiro Ikegami and Jeff Slingluff (Roland/Boss US ) at 2017 Winter NAMM (6 weeks away)
So let's get our wish lists prepared
Synthetica
While i am at it add a Noise Gate FX option in addition to the already included Noise Supressor.
PhD
To my opinion, the patch selection should be changed to avoid each intermediate one to be activated during a new selection.
For the moment, if one wants to go from patch A to patch Z, the system will launch each patch in between (B,C,D,...).
One could I think easily program something like:
   - Select the new patch with the up or down
   - until you reach the target patch
   - then, when done (or when required), either
           * push the CTRL1 short to activate the new selection.
           * push the CTRL1 long to cancel
Just an idea to avoid strange noises when one has to skip 10 patches between actual and final...   :)
Something like a special menu selectable patch change mode, where the patch up/down will select the next patch, but only change to that patch when you tap the CTL pedal. (patch change wait).
pasha811
Assign a specific patch to each of the free pedals on GT-1 (Up-Down-CTRL1)
That will be great for 'lean' setups where you need the same 3  patches in the gig with the addition of two modifiers (CTRL2-3) per patch.
Alternatively, let Up/Down be assigned to Assign controls (today they only switch on off blocks or add level volume or solo)
;D
pasha811
Can I add a wish list for GP-10 here?
PhD
Quote from: pasha811 on December 14, 2016, 02:20:38 AM
Hmmm there is a set for the GP-10, it should not be in this one which is definitely GT-1... If we start mixing different devices, it will rapidly become useless... Just my option.
pasha811
Quote from: PhD on December 14, 2016, 02:50:49 AM
Agreed. Thx!
slimefuzz
#9
-square or pulse wave shape for wavepedal and modulation effects
-smooth delay time changes: currently can click when changing tap tempo or delay division
-assignable parameters for exp switch same as ctrl 1, 2, 3 using assigns. eg: turn on wah AND comp or OD at same press.
-stereo looper
-more chorus models
-regular reverse delay that plays the whole delay time backwards without chopping
-much better pitch shifting
-dim mode for LED's
pkort
Oh, I have some for GT-1(B) as well, any luck for an update?
