GP-10 - Automatic Volume Swells?
Started by Singwas, June 21, 2016, 05:54:23 AM
Singwas
Does someone have an idea how to do auto volume swells with a GP-10? Like the Moeer Slow Engine?
GR 55
Godin LGXSA
Roland Testgitarre
slooky
I just bought the Mooer slow engine, sounds nice except its a little noisy when engaged, as for creating it on the Gp-10 I am not sure
GP-10 lacks a Boss Slow Gear emulation
But there is a "Slow PAD" under the Poly FX
Would wave and internal pedal mapped to volume work ?
I'm not sure but worth a try
Otherwise Slow pad is really good
It's flawed , but you can create a Control Assignment with  Internal pedal as source to control a Volume target
But this requires retriggering the GP-10 patch you set these Control assignments work as a volume swell upon 1st selection of the patch  -that requires a MIDX-10 and a separate MIDI Controller for direct GP-10 patch selection
if you use Wave pedal your control source you  end up with a tremolo/ stutter effect -dependent upon the choice of wave pedal waveform
