Boss GT100 Send/Return
Started by NickyC, June 20, 2016, 12:51:37 PM
NickyC
I use the GT100 in manual mode, 4CM with modulation effects after the GT100 send/return.  Recently, and for no reason I can figure out, the GT100 send/return stopped working and I now only get a signal when its switched off.  I'm assuming there is a fault on the GT100 but wonder if anyone else has had the same issue?
Could be the amp or the cables, assuming it is in normal mode, try a patch lead from the send to the return of the GT-100 to check the S/R loop is working when 'on'
NickyC
Thanks for the reply - it was a dodgy cable!
