Fishman TriplePlay FC-1 Floor Controller (User Experience)
Started by vablows, January 25, 2015, 10:19:57 AM
yuri
     Russian site  .I found this,  also  I think to  buying this just comes out http://musicbox.su/fishman-tripleplay-floor-controller/
A good indicator of how bad the economy is in USA, when Fishman markets this new product everywhere - EXCEPT the USA.
yuri
ha , ha   here is even worse....  In any case ,  my  general vision  about all this  -In the past I used roland gr 55, etc mahh......  But FTP ! I think this possibility with FTP and  external  control (expander midi synth generator ) without  PC , Mac  -  Great !  most  important jump   in the last 20 years for guitar as instrument   for total  creativity  . Also  world  famous musician  and composer Goran Bregovic  uses only midi (for live show and  at  studio)only   midi .
In April 2011 we went to Goran's house to document the preliminary production process of my debut single, "Jealous Monster". This project is now known as "The Anca Pop Project".
http://ancapop.com
http://andipopescu.com
http://goranbregovic.rs
polaris20
I'm hoping the USB output is class-compliant, so I can still plug this into the iPad, BUT have control over which hardware sensitivity is being used, and perhaps change patches in Sampletank on the iPad.
TPguitarman
Quote from: Elantric on January 26, 2015, 10:23:41 AM
Fishman Tripleplay Floor Controller
Due April 2015 for $200 Street price
Foot pedal for the existing Tripleplay USB Receiver . It's an accessory for all existing and new FTP users.
Its a USB Host to 5pin MIDI I/O converter ( the existing FTP USB Receiver plugs in on the upper right top of the unit , with Three foot switches, 5 pin MIDI I/O , USB Host port, 1/4"  Guitar I/O jacks which are simply there to provide an internal audio relay mute switch as a means for the guitar mounted FTP Controller's three way switch to mute the normal Guitar signal when in the "Synth" position.
Its not a USB Audio Interface, but might also work as a USB Class compliant 5 pin MIDI Interface.
I understand deeper program-ability for this new Floor controller  - with selectable MIDI channels for the MIDI Mono Mode Note on/off transmission and user selectable Pitch bend range will be supported  by a new updated version of the Win/OSX FTP Control Panel app due Spring 2015
Below  matches what I know
I voiced a strong desire for a dedicated IOS App for FTP setup / configuration - but I was told thats not going to happen
+1 im with you on this, I posted on fishman fb page also, wonder whats they thinkin of it on future updates but for now I think they don't have plans for IOS
 Fishman Tripleplay Foot Controller
I suspect this has been pushed back for a summer 2015 release
I think I'll wait for the model where it's easier to step on a button than the FTP receiver...
QuoteI think I'll wait for the model where it's easier to step on a button than the FTP receiver...
I share same thoughts here
tydacor
Will the FTP floor unit come with its own preset of sounds.
Read prior  posts for all features
Adapter  / controller only - No built in sounds  -
TG
Fishman TriplePlay FC-1 Floor Controller MIDI Floor Controller for FTP  - $199
http://www.sweetwater.com/store/detail/TripleplayFC1
Unlock your Fishman TriplePlay MIDI System
Leave your computer off the stage with the Fishman TriplePlay FC-1 Floor Controller. With its USB host, multi-function footswitches, and MIDI I/O you can connect your sound modules and synths directly. The three footswitches let you step through TriplePlay patches and change presets on your MIDI devices. And the bright, graphic display shows patch names and numbers, plus a variety of status indicators so you're in total control the whole time. With so much functionality inside the FC-1 Controller, you'll open up a world of uses with your Fishman TriplePlay.
Fishman TriplePlay FC-1 Floor Controller Features:
All-in-one foot controller for your Fishman TriplePlay MIDI pickup
It connects to your DAW as a USB peripheral
Stomp-box style footswitches for easy use while playing
Expression pedal input gives added control
Class compliant MIDI interface
Included Mac/Win utility software
Road-ready design
Built-in tuner
Sustain/hold functionality
Relay switcher for mixing guitar and MIDI sounds
Use your Fishman TriplePlay like never before with the FC-1 Floor Controller!
Tech Specs
Type   Foot Controller
Power Supply Included   Yes
Height   2.4"
Width   9.3"
Depth   5.4"
Weight   1.35 lbs.
pje
See here:
FTP accessories
https://www.vguitarforums.com/smf/index.php?topic=9032.msg64948#msg64948
TriplePlay USB Receiver
USB Receiver for the TriplePlay system.
Use this receiver to pair with any TriplePlay controller and pickup. Note that only 1 receiver can be used with a single pickup and controller at the same time.
Product Code: ACC-TRP-REC
In Stock: Yes
Price (USD): $69.95
http://www.fishmanstore.com/product.htm?pid=735727
kenact
Has there been any talk about a group buy for the FC-1 yet?
Danoblaster Baritone w/GK-3
Gretsch Nashville, Viking
Fender Strats
Fret King Supermatic
Larrivee DV03RE
Parker Midi Fly
Seagull, S&P 12
VOX Phantom XII
Sentient 6
Cyr 7
http://www.sweetwater.com/insync/summer-namm-2015-fishman-tripleplay-fc-1/
Leave your computer off the stage with the Fishman TriplePlay FC-1 Floor Controller. With its USB host, multi-function footswitches, and MIDI I/O, you can connect your sound modules and synths directly. The three footswitches let you step through TriplePlay patches and change presets on your MIDI devices. And the bright graphic display shows patch names and numbers, plus a variety of status indicators, so you're in total control the whole time. With so much functionality inside the FC-1 Controller, you'll open up a world of uses with your Fishman TriplePlay.
Connects to your DAW as a USB peripheral
TPguitarman
Stratcat52
That looks definitely like a nice addition but if one is just looking to connect to hardware there must be some less expensive way.
What are alternatives please?
QuoteThat looks definitely like a nice addition but if one is just looking to connect to hardware there must be some less expensive way.
* Raspberry PI $35 + Generic USB to MIDI cable ($15)
* iConnnectMIDI (original Black version - discontinued )
* iConnnectMIDI4+  (not the iConnnectMIDI2+ ! ! )
* Kenton USB Host to MIDI Converter
* Primova MIDX-10
https://www.vguitarforums.com/smf/index.php?topic=15758.0
Its a shame Fishman did not employ more protection for the fragile FTP USB Receiver
(Comments)
https://www.vguitarforums.com/smf/index.php?topic=15760.msg112497#msg112497
The current  TriplePlay FC-1 Floor Controller design leaves the FTP USB Receiver exposed too close to a foot switch and is likely to be stepped on
(wish USB Host port was behind a door like GR-55, and offer more protection for the FTP USB Receiver
- i suspect they did not want to restrict the RF communication to the FTP Controller on the guitar , which would occur if the  FTP USB Receiver was inside a metal box)
For future TriplePlay FC-1 Floor Controller owners, there are third party USB Extenders  that can relocate the FTP USB Receiver out of harms way
http://www.amazon.com/StarTech-5ft-Desktop-Extension-Cable/dp/B001K9BFB8
tracy
The FC-1 looks like a nice gadget to have for those still into DIN plugs. The patch list is stored in the encoder! Wow, freaky. Had no idea it did that.
But really, even the new $200 gadget needs the dongle? Ugh. I guess it keeps the cost lower, but dongles have always been one of the evils of music software. Mine always tend to wander off at the worst times.
@tracyevans    •     http://www.exhibitry.com
stratrat
This is frustrating for me - they have a potentially great product, but just don't seem to have any idea what the needs of most working musicians are. I need something I can gig, and dongles don't cut it - let alone placed in a perfect position to kick or stomp on (on a pedal made for stomping!). One misstep and it's toast...
Now, if they had just put in a little recessed flip out port, like on the GR-55, it would have at least been usable. Hell, add a 13-pin socket to the box too and they would have access to the existing 13-pin user base (and cater for those of us who play nylons too).
tracy
Quote from: stratrat on August 02, 2015, 07:12:52 AM
Not surprisingly, I agree with your comments that dongles don't cut it, but if you want 13 pins there is already a product line/culture/religion for that direction. Fisherman seems to be all about wireless, for better or for worse.
Pity that while all current computing devices have multiple wireless ins and outs, Fishman seems to be anchored in an era of belief that devices manufactures install radio receivers and need help from USB dongles. which was that case maybe, what, 10 years ago?
However, it could very well be that I know nothing of which I speak and the magic that Fishman performs with their dongle can't be replicated with the receivers in current Macs, PCs and iDevices. It would be interesting to know which is the case.
QuotePity that while all current computing devices have multiple wireless ins and outs, Fishman seems to be anchored in an era of belief that devices manufactures install radio receivers and need help from USB dongles. which was that case maybe, what, 10 years ago?
Fishman Tripleplay uses a 2.4GHz Wireless communication protocol that is proprietary, and is not compatible with standard Wifi 802.11, Bluetooth, Zigbee, etc.
