Tripleplay 64-bit and 32 lives problem
Started by Deleuze1, July 28, 2014, 05:37:02 AM
Deleuze1
My Fishman Tripleplay 64-bit does not seem to work with 32 Lives.  Are they incompatible?  Is there a reason they would not work together (I used to think they did)?  I have reinstalled both apps, but no luck.
Thanks for any help!
Read the FTP Docs to learn how to start FTP Control Panel in 32 bit mode.
Deleuze1
thanks, elantric.  I know how to run FTP in 32-bit, but want to stay in 64-bit to work with my other DAWs (Logic, Ableton).  Perhaps the problem is with 32 Lives...
Ahhhh.... Within a DAW...
Basically, don't run the VST within Fishman within your DAW.    Split them into two tracks, one running FTP with a "HW Synth" patch loaded, and one running your VST natively within the DAW, with the FTP as it's MIDI input device.  This is described in detail here:
https://www.vguitarforums.com/smf/index.php?topic=10481.msg75783#msg75783
And read this whole thread for some helpful related info:
https://www.vguitarforums.com/smf/index.php?topic=9952.0
Shawn
