FTP- Issues with pitch bend and sample tank iOS.
Started by Fatigueofheart, December 07, 2014, 01:58:57 PM
Fatigueofheart
Has anyone manage to get pitch bend to work in iOS sample tank?
I've tried all settings in hardware mode with no success.
BackDAWman
I think the PB range on the iOS ST is fixed at +/- 2 steps. I could never find a way of changing this and therefore never use PB on iOS ST. If anyone knows a workaround it would be greatly appreciated.
SampleTank for IOS Owners manual is attached
IK Sampletank for IOS Forum
http://cgi.ikmultimedia.com/ikforum/viewforum.php?f=18&sid=839bfd20fef0108c0b93053d3ac9f5e8
Fatigueofheart
I still haven't found solution to this problem.
Turns out it's not just sample tank but any IOS app as well. I'm in hardware mode.
No mention in the ST for IOS manual.
The only hints in the IK ST IOS forum are folks asking for more range.
Fatigue - Pitch Bend Range must be set on *both* the FTP side and on the synth side, and the two settings should be *in sync*.
   -  Are you sure you have it set right on the FTP side?
   -  Are you sure that your IOS synths support a range > 2 semitones?
I don't use the IOS apps (in part due to limitations like this).
