Midi program changes from Logic to GR55 and Line 6 M 13
Started by doha1696, June 11, 2011, 02:20:22 PM
doha1696
I want t do this :
Logic transmits PC to the GR 55 via USB from my Mac Book Pro. That works well. The problem is that I also need to change programes on my Line M13 stompbox modeler. I connected the GR 55 midi Out to the M13 midi in, thinking that my Macbook would send PC to the GR55 that would send PC to the M13. But it seems to be impossible to do that. PC change well on the GR55 but The GR55 does not send PC to the M13.
What's very strange is that when I use the switches of the GR55, PC are transmitted correctly to the M13......
A solution ?
Bye
Dominik Hardy
http://fret-time.com
Quote from: doha1696 on June 11, 2011, 02:20:22 PM
I want t do this :
A solution ?
Bye
The GR-55 USB is not a midi hub, and the GR-55 does not chain through midi data from the USB to the 5-pin ports.
You will need a separate USB/Midi device for the M-13 pedal
doha1696
OK that's what I thought and it's a real problem for me. In fact, what I wanted to be able to do was to use the GR55 expression pedal to play a wha on the GR55 at the same time I play a wha on the M13, using the GR55 midi Out and the M13 midi In... It seems to be possible to do that but only when you don't use program changes coming from Logic. If you see a solution.... please tell me...
Dominik Hardy
chatschbach
Hi
A can't connect the GR55 to Logic Pro by USB
Logic pro recognized the GR55  but I can record or listen the playback
All the plugins disappear when I use the GR55
If  I change to other output or input, everything goes well
