Amp Send/Return question.
Started by JCcares, August 14, 2015, 06:36:59 AM
JCcares
 have a Roland GR55 which has no send or return.However the amp that I would be plugging (Spider valve & a Peavey amp Valve King) does have a send & return input.Now if I connect a distortion stomp box via the send/return inputs will the distortion be placed before or after the GR55.Is there anyway I can change thel rig order so the distortion is connected before the GR? I won't be able to do this any other way since the GR55 needs a v different type of cable.
Your amp FX Loop RETURN is the best place to to connect the GR-55 Left Output and run in Mono
For inserting FX in front of GR-55 This works - but only for the normal mag PUs
Normal 1/4" Guitar out > External Distortion FX> GK-3 1/4" Input
read
GR-55 guitar pickup input output fx loop Mod with Pictures!
https://www.vguitarforums.com/smf/index.php?topic=3994.0
also
GR-55- Creating an external effects loop for the modeling tones
https://www.vguitarforums.com/smf/index.php?topic=3793.0
