How can I step through patches one by one with an FC300
Started by lesxm, September 14, 2014, 12:05:18 AM
lesxm
Hi everyone, I'm new to the VG-99, but plan to use one in a theatre pit band using different patches ordered sequentially as they appear in the show using VG Librarian. How can I achieve this using FC300, in the same way as the VG-99 control knob does, with only Up or Down switches, i.e. not changing banks.
Thanks for any help.
musicman65
You can't, unless someone else knows a trick. You can step through 5 then bank up. That's how it's designed. You can bank up without it changing to get ready for the next patch change.
lesxm
clearlight
im not sure but you may be able to use pedal assign for that. not sure but look into it
My Music
My Band Website
GUITARS: 2x RG1521, 3x RG321 w/gk, Rg721 Fretless Modified, AmStd FatStrat w/gk, various others....
XV5050,Triton etc..
KOMPLETE 7
VGUITAR Stuff: VG99, FC300, RC5-
pasha811
Just yesterday I was able to assign up/down patch do CTRL3 CTRL4 pedals from the global assignments page in VG99. I have a sort of FP-6 that did the trick attached directly to VG99.
I have no FC300 but I hope that this can be done through a FC300 as well. In the rear of FC300 there are plugs for CTRL 3/4, 5/6, 7/8.
So I assume that the CTRL 3/4 should mimic the CTRL 3/4 on the rear of the VG99.. But assuming what Roland Engineers had in mind might turn to headache sometimes..  ;D
Good Luck,
Best
Pasha
you can also assign the GK switches,
as well as CTRL3 CTRL4 pedals (using 2 FS-5U switches straight into VG )
