VG-99 - Resetting the vg-99
Started by iainaw, June 30, 2014, 10:32:27 PM
iainaw
If i were to factory reset which should i choose?? So I can keep the firmware version 1.04 and gk- 3 settings... Just 'reset the rest of the vg-99
VG-99 & FC 300, GR-20, Mesa boogie Triaxis, TC Electronics G-Force, Malmsteen Strat, Peavey Wolgang (with internal GK-3), Jackson Dinky, 50th Anniversary Strat, And other stuff ... Too much stuff ask my wife!...
Performing a "Factory Reset" does not change nor impact the currently loaded firmware.
But it will over write all your personal SYSTEM Settings  - so use the VG-99 Editor / Librarian  and make a full backup first.
VG-99 Reset Procedure
Disconnect all cables for at least 5 minutes.
Press the SYSTEM button.
Press PAGE three times
Then press F1
You should be using VG-99 FW 1.04 for best performance and most compatibility with all files here.
VG-99 FAQ: TOP THINGS TO KNOW
* Latest VG-99 Firmware 1.04
https://www.vguitarforums.com/smf/index.php?topic=14.0
iainaw
