GR-55 USB Driver Installation and Librarian Tutorials
Started by Elantric, February 06, 2011, 09:01:59 AM
Machh_2
HI
i downloaded the GR55 driver (XP) from Roland site, but the instalation dont work, if i decompress the driver on some file, and click "setup" the program says: " setup.dat" dont exist, but the file is there.If i run instalation directly from zip file the screen the instalation opens but says "error occur" , finish instalarion...
what happen? the driver is corrupted?
Machh
Full install instructions for GR-55 WinXP USB Driver is here:
https://www.vguitarforums.com/smf/index.php?action=dlattach;topic=3050.0;attach=3316
Be sure to download the driver from here:
http://www.roland.com/support/article/?q=downloads&p=GR-55&id=57277729
I have attached GR-55 USB WinXP Driver installation instructions in Portuguese
Machh_2
hello !
tnx for your fast hlp !!!!
thanks for your care to post the information in my language.
i wish you success ...
Machh
Machh_2
hello !
i dowloaded the driver from your link, i try 3 times to the instalation, and dont work, so, im try one more time, and dont know why, works well.
the librarian was already instaled...
after all this work, conect the GR on usb e i can read all data to computer...
now i try some patches posted on forum...
tnx for your hlp
Rexx
I've tried for a month to use the Roland Librarian and the GR-55 Floorboard and with both all my Saves and Exports are not visible to Windows 7 only to these Apps.  With Floorboard I created a new folder in 'Saved Patches' I named 'Rex Patches' but that folder is locked and invisible to my OS, ditto with Roland Librarian.
Probably the only one unique to this issue (I can save and load but I'm afraid to try in fear of losing my own presets)
I simply cannot point to my own .G5l patches for sharing, thus rendering the whole midi librarian concept unusable.
Quote from: Rexx on March 25, 2012, 12:21:49 PM
Does your computer have account restrictions? Such as the need to log-on with administartor priviledges.
Another issue might be the Folder View setting, from your 'File Explorer', click on 'Tools' and 'Folder Options', and change settings to suit.
Also Be sure to un-click "Hide file extensions", in Windows Explorer folder properties.
Rexx
Thanks Guys!  I hope to try these suggestions out in the coming days when i get tme.  :)
GR-55 Driver for OSX 10.8 Mountain Lion download
http://www.rolandus.com/products/details/1148/477
Note: (November, 2013) If you are using a new PC/Mac running Win8.1 or OSX 10.9 Mavericks - you must wait for Roland to release the updated GR-55 USB driver that will work under those new systems.( expected delivery Jan 2014)
Roland USB Drivers - Get latest Status
https://www.vguitarforums.com/smf/index.php?topic=9763.0
Roland GR-55 USB Driver for OSX Mavericks
http://www.rolandus.com/support/eula/gr55_mx9d_v101.tgz
GR-55 Driver Ver.1.0.1 for OS X 10.9
This is a driver for using the GR-55 on OS X 10.9.
Products?GR-55
[ CAUTION ]
* If Mac sleeps while playing a music file in the Finder, and then Mac resumes, the Finder may freeze. Here's procedures to recover the Finder:
Press command - option - esc keys at the same time.
Choose Finder and click [Relaunch] button.
The display will indicate "Do you want to force Finder to quit?"; click [Relaunch] button.
* If Mac sleeps while using an audio application, like DAW, and then Mac resumes, playback/recording may not work. If this happens, please relaunch the audio application.
Apple and Roland are looking into these two issues now.
System requirements
This driver has the following requirements.
* Please also check the System requirements for the audio/MIDI application and the operating system you're using.
Operating System
OS X v10.9
Computer
Apple Mac series computer with on-board USB
* Even if connected to a USB 3.0 port, the performance of the product will not change.
* Mac computers running Microsoft Windows are not supported.
Windows  -  fixing the "10 USB driver install limit" issue with Roland/Boss USB Drivers for Windows
http://www.roland.com/support/knowledge_base/201930949
PROBLEMS INSTALLING USB DRIVERS IN WINDOWS
Tags: driver, usb, xv-2020, r-1, ua-5, ua-20, ua-25, ua-1ex, ua-1000, ua-101, r-9
The can be several reasons why a USB driver may appear to not be installed correctly in Windows. Here are some things to check.
You may have installed it but not selected it. Be sure to check Control Panel > Sounds and Audio Devices > Audio and see if the USB Audio Device is selected as the default Input and Output. If it's found there, it should also be available in your recording software.
If the interface does not appear in your recording software, it may be that your USB cable is bad (replace it) or that you have reached a "device limit" in Windows. This is characterized by USB drivers appearing to be installed correctly but not seeing audio or MIDI ports in recording software. The problem is caused by a 10 USB driver limitation in Windows XP/2000.
USB Driver Limitation Solution:
1. Click on "Start" and choose "Run," then type in "cmd" as the command line. Click "OK" and a DOS prompt will open.
2. Type the following commands one line at a time, hitting enter after each:
set devmgr_show_nonpresent_devices=1
start devmgmt.msc
3. The Device Manager will now open up, so click on the View menu and choose "Show Hidden Devices." Look through the device manager carefully and note that there are a lot of drivers with a kind of translucent colored icon next to them. These are what are called "ghosting" or otherwise nonpresent drivers your computer is remembering in case you were to ever use the device again later. They can also be drivers that do system functions and are hidden by default, or partially installed or corrupted driver install attempts, all sorts of things really.
Look under these categories in particular:
+Human Interface Devices
+Other Devices
+Sound, video and game controllers
+Universal serial bus controllers
4. Uninstall any driver that shouldn't be there, but pay particular attention to things like these:
USB Composite Device
Composite USB Device
USB Audio Device
USB Human Interface Device
USB Device
Unknown Device
*3rd party USB drivers no longer in use or installed multiple times.
*Edirol drivers you are having problems installing.
Delete these or any driver duplicates and then restart your computer.
5. After you have completed these instructions your Roland/Edirol USB driver should be reinstalled to end the procedure. MIDI and audio ports will then be visible in your software.
laurentjanisz
Hello,
I am new on VG guitar forums. great source of information and exchange platform. :)
I have a GR55 and bought a Roland UM-ONE USB midi cable in order to work with GR librarian and floorboard installed on OS X 10 Yosemite.
I installed the UM-ONE with success following carefully the installation procedure.
Regarding the GR55 driver, I had a message telling me that it has been successfully installed but the midi studio did not show the GR55 (the same in audio setup). I tried ti follow the procedure explained in the doc: MIDI re-initialization but it did not work.
I decided to uninstalled bu there is no uninstallation soft included in the pack  ??? so I deleted the BOSS file related to the GR55 USB driver. Tried to re-install many times...I think I have read all the valuable suggestions I could find on the forum but no success.
I am really stuck....did some body met the same problem? ...any advises?
Quote from: laurentjanisz on August 23, 2015, 03:36:47 AMI have a GR55 and bought a Roland UM-ONE USB midi cable in order to work with GR librarian and floorboard installed on OS X 10 Yosemite.
Why use the UM-ONE when the GR-55 connects via USB to provide USB Audio and Midi, the UM-ONE is not required.
When installing the GR-55 USB driver, is the GR-55 USB being plugged in to the computer?
Your midi and audio devices in your software will show as "GR-55"
laurentjanisz
#37
Thanks for your message Gumtown. I thought M-ONE was required to use the GR55 librarian....if not required, so I spent 38 euros for nothing as I had already a USB cable. :(
Anyway, when I installed the GR55 driver, I had nothing plugged in the computer as mentioned in the GR55 read me file.
I checked afterwards in the Application menu: I see indeed the BOSS file included a GR55 driver file...I see also the GR55 driver parameter in "system preferences": Everything looks like the driver is installed.
However, in "system preferences", when I click on "sound", I see no trace of GR55 (like in the MIDI studio).
________________________
I tried today with a USB cable and everything worked fine. GR55 was visible in both MIDI studio and Audio settings.
Thanks for your advice. Synth and MIDI world is new for me.
Oskykid
I've attempted driver setup for Windows 7 multiple times now.  Norton declares a .dll file at a threat and deletes it.  Any clues as to what is wrong and how to get around it?
Thanks!
QuoteI've attempted driver setup for Windows 7 multiple times now.  Norton declares a .dll file at a threat and deletes it.  Any clues as to what is wrong and how to get around it?
Be sure you are obtaining your Roland GR-55 USB Driver from Roland
Must follow the exact instructions for installing the Roland  USB Driver for your Operating System. This is available as a "Read_Me.HTML" file contained inside the Roland USB Driver Zip file
Or click here for a PDF version
Win7 Install Instructions (pdf)
https://www.vguitarforums.com/smf/index.php?action=dlattach;topic=3050.0;attach=3315
Oskykid
Definitely from Roland.  I used the links provided in this thread.  I had no problem with the library software, just the driver.
Oskykid
The specific file it removes as a threat is RDA51113.DLL
Oskykid
I got some help from Norton - and I had to temporarily shut security down.  Success!
GR-55 LIBRARIAN FOR WINDOWS
GR-55 Librarian is a software that allows you to manage Sound patches in the GR-55 with your computer.
How to install
Please download and open gr55_winlib_v100.zip file, then put the "setup.exe" onto your computer's suitable directory.
Double-click "setup.exe", then follow the messages displayed in the window.
System Requirements
Operating System
Microsoft(R) Windows(R) 10
Microsoft(R) Windows(R) 8 / 8.1
Microsoft(R) Windows(R) 7
Microsoft(R) Windows Vista(R)
Microsoft(R) Windows(R) XP Professional
Microsoft(R) Windows(R) XP HomeEdition
*Librarian does not support Windows(R) XP Media Center Edition.
CPU/Clock
Intel(R) Core(TM)/Pentium(R) 1.5 GHz or higher
Memory
512 MB or more
Hard Disk Space
150 MB or more
Graphics
1024 x 768 dots or higher, 24-bit Full Color or more
Others
A computer with a USB connector that supports USB Specification Revision 2.0 or later.
Adobe Reader (available free of charge) is required in order to view the online manual.
* Although Roland has tested numerous configurations, and has determined that on average, a computer system similar to that described above will permit normal operation of the GR-55 Librarian, Roland cannot guarantee that a given computer can be used satisfactorily with the GR-55 Librarian based solely on the fact that it meets the above requirements. This is because there are too many other variables that may influence the processing environment, including differences in motherboard design and the particular combination of other devices involved.
http://www.roland.com/support/by_product/gr-55/updates_drivers/4925
http://www.roland.com/support/by_product/gr-55/updates_drivers/350854
GR-55 DRIVER VER.1.0.0 FOR WINDOWS 10
This contains information on the gr-55 driver compatible with Microsoft Windows 10.
Driver for Windows 10
Your computer automatically downloads the Windows(R) 10 driver from the Internet when a product requiring the driver is connected to the computer.
For detailed information about the driver, check "Download File" at the bottom of this page.
* Under normal conditions, the driver installation is completed in several minutes. It may take about 10 minutes depending on the Internet connectivity or if there are other drivers being installed for other devices.
* A problem may have occurred if the device is connected but cannot be used after waiting for 10 minutes. Download the detailed information for the driver and refer to "Troubleshooting."
System requirements
Operating System
Microsoft(R) Windows(R) 10 ( 64-bit Edition / 32-bit Edition )
* Windows 10 Mobile is not supported.
Computer
Windows-compatible PC equipped with USB port
* Intel chipset is recommended.
* The device may not perform to its full specs when used with an added USB 2.0 interface card.
* This product cannot be used with a USB 3.0 port that is not compatible with USB 2.0 specification.
* If this product does not work correctly when connected to a USB 3.0 port, you will need to connect it to a USB 2.0 port.
* This driver cannot be used in a virtual Windows environment, such as Hyper-V or Virtual PC.
Other
Internet connection
* The Internet connection is needed to download the driver.
GR-55 Driver Ver.1.0.0 for Windows® 10
(Note)
In no event shall Roland Corporation ("Roland") be liable to end-users for any damages whatsoever, including but not limited to financial damages for loss of business profits or business information arising from the use of, or inability to use this product. The foregoing provision is effective even if Roland has been advised of the possibility of such damages.
*   Any modification, duplication, distribution, or reproduction of material (including the files related to this driver) without permission from Roland Corporation ("Roland") is prohibited.
*   Microsoft and Windows are either registered trademarks or trademarks of Microsoft Corporation in the United States and/or other countries.
*   ASIO is a trademark and software of Steinberg Media Technologies GmbH.
*   All product names mentioned in this document are trademarks or registered trademarks of their respective owners.
Your computer downloads the Windows® 10 driver for GR-55 automatically from the Internet when GR-55 is connected to the computer.
This driver also supports ASIO(Steinberg Audio Stream I/O Interface).
*   When using a touch-enabled PC, replace the words "click" and "right-click" in this document with "tap" and "press and hold", respectively.
System requirements
Operating System
Microsoft® Windows® 10 (64-bit Edition/32-bit Edition)
Computer
*   GR-55 may not perform to its full specs when used with an added USB 2.0 interface card.
Other
Internet connection
Cautions and Limitations
Sound interruption or other less-than-perfect outcomes may be experienced if your computer's performance and specifications are somewhat inadequate. The types of applications you use and the way in which you use them can also influence the experience you receive.
If the PC is started up while the GR-55 is still connected to the PC with its power turned on, the driver may not be loaded properly and you may not be able to use the GR-55. In such cases, connect the GR-55 to another USB port or turn on the power of GR-55 after the PC starts up.
If the GR-55 does not work correctly after resuming from Sleep mode, you should exit all applications that use the GR-55, and then turn the power of the GR-55 off and on again.
If the USB cable is disconnected and reconnected while the GR-55 is in use, or if the power of the GR-55 is turned off, then on again, it may stop operating correctly. If this occurs, after resuming, you should exit all applications that use the GR-55, and turn the power of the GR-55 off, then on again.
If your computer was experiencing a heavy processing load, such as when accessing a CD-ROM Drive or network while the GR-55 was being used, the GR-55 may no longer operate correctly. If this occurs, stop the playback or recording, then try starting playback or recording over again. If you are still unable to play back or record, quit all programs that are using the GR-55, then turn the GR-55 off and then on again.
Audio clicks and pops may occur during playback or recording if you connect or disconnect other USB devices (such as USB memory) or turn another USB device on/off while using the GR-55.
In some cases, you may not obtain the expected level of performance if you're using a USB-connected hard disk at the same time as the GR-55. Do not use a USB-connected hard disk as the storage destination for the audio that you're playing back or recording.
Installation
*   To reinstall or update the driver, refer to "To reinstall."
Disconnect all USB devices except keyboard and mouse, and then start Windows.
Check that the computer is connected to the Internet.
On Windows, close the "Sound" settings screen of the Control Panel and all running applications.
Turn on the power of GR-55 and connect it to the computer using a USB cable.
The driver will be installed automatically.
After several minutes, click the start button and then click "All apps".
Open the Roland folder. If the "GR-55" icon is displayed, the installation is completed.
*   Under normal conditions, the driver installation is completed in several minutes.It may take about 10 minutes depending on the Internet connectivity or if there are other drivers being installed for other devices.
*   A problem may have occurred if GR-55 is connected but cannot be used after waiting for 10 minutes.Refer to "Troubleshooting."
Before you begin
Input/output device settings for your application
In order to obtain optimal performance from your applications, specify the input/output device for your applications as described below. (For details on making these settings, refer to the owner's manual for your application.)
*   Ensure that the GR-55 and the application are set to the same sampling frequency. If the sampling frequency settings do not match, error messages may be displayed and recording/playback errors may occur.
*   If you are unable to select the GR-55 device, a problem may have occurred. Refer to "Troubleshooting."
Audio Playback/Recording devices
Of the total audio input/output channels provided by the GR-55, there are 2 INs and 2 OUTs
You can use the Playback/Recording devices shown below.
[Playback devices]
OUT (GR-55)
*   If you've specified a different name in the "Sound" settings of the Control Panel, the name you specified will be displayed.
[Recording devices]
IN (GR-55)
Setting the playback/recording device in Windows
Set GR-55 as the default device to allow its use in "Groove Music" and Windows Media Player.
Right-click the start button and then click "Control Panel".
Click "Hardware and Sound" and then click "Sound".
*   If the icon view is selected for the Control Panel, click "Sound."
In "Playback," right-click GR-55's "OUT," and choose "Set as Default Device."
*   A problem may have occurred if the devices above cannot be selected.
Similarly, in "Recording," right-click GR-55's "IN," and choose "Set as Default Device."
Click [OK] to close "Sound."
Device settings for ASIO-compatible applications
When using the GR-55 with an ASIO-compatible application, select "GR-55" as the ASIO setting for your application.
*   To prevent an audio feedback loop or double monitoring, make settings on your application to turn monitoring off.
*   The GR-55 main unit does not support ASIO Direct Monitor, but if you use Cubase, by enabling Direct Monitoring in the Cubase setting, you can prevent loop oscillation of audio equipment and duplicate monitoring.
*   When using the GR-55 with ASIO, we recommend that you set your application so that it does not use the Microsoft GS Wavetable Synth. (In order to decrease the load, and for convenience when changing Audio Buffer Size of the driver.)
MIDI input/output device
*   In the Windows Media Player, the MIDI input/output device of GR-55 cannot be used.
Please select the following device in your MIDI compatible application.
[MIDI OUT devices]
GR-55
[MIDI IN devices]
GR-55
Opening online document
When the driver installation is completed, you can open the Readme file (this document) by following the procedure described below.
Use this file for troubleshooting and for checking how to set up the driver.
Click the start button and then click "All apps".
Open the Roland folder and then click "GR-55 Readme".
The online document for the driver is displayed.
Changing/checking driver settings
When changing driver settings, always make sure to first quit all applications using the GR-55. This is unnecessary when only checking the settings.
*   Please wait for about 10 seconds until these applications exit completely.
*   If the Windows monitoring function is enabled, it won't be possible to change the driver settings. Refer to "Could the Windows monitoring function be enabled?" and disable monitoring.
Open the Roland folder and then click "GR-55".
The "GR-55 Driver Settings" dialog box will appear.
*   You can also open the GR-55 Driver Settings dialog box from the Windows Control Panel.In the Control Panel, click View by: and change it to an icon display, and then double-click the GR-55 icon.
To modify the settings, make the changes and click [OK]. To simply check the settings, be sure to click [Cancel] after viewing the settings.
*   For details on the setting items, refer to "About the items in the Settings dialog box."
Audio Buffer Size
You can adjust the audio input/output buffer size. (By default, this will be the sixth position from the left.)
Decreasing the buffer size will shorten the latency and improve realtime performance, but might make it more likely that you will experience audio clicks and pops, depending on your computer's processing power and the song data load.
Increasing the buffer size will lengthen the latency, but will make audio streaming more stable, and it will be less likely for audio clicks and pops to occur.
In general, you'll probably want to decrease the buffer size for better realtime performance if you're playing a software synthesizer in real time, or if you're monitoring an audio input that's being passed through your DAW software.
Conversely, you can increase the buffer size to prevent audio clicks and pops if you're recording or playing back song data that contains numerous tracks and presents a heavy processing load.
By changing the buffer size as appropriate for your situation, you can obtain the right balance between realtime performance and audio streaming stability.
* Note!
If you use an application with an audio equipment test function, after changing the buffer size, carry out a test.
ASIO Buffer Size
This is the minimum buffer size that can be set by the ASIO application.
*   Depending on the application you're using, there may be other buffer sizes that can be set in addition to the minimum buffer size, and the buffer size shown here might not match the actual buffer size.
For details on setting and checking the buffer size, refer to the owner's manual for your application.
"Use Smaller ASIO Buffer Size" check box
If this check box is selected, the buffer size when using ASIO-compatible applications will be made smaller.
If you experience pops or clicks when this check box is selected, deselect this check box.
*   You must deselect this check box when adjusting the "Audio Buffer Size."
"Show README" button
This button displays the README file (this document).
Information
This field shows the driver version.
To reinstall
Delete the driver as described in "To uninstall."
*   When you uninstall, the settings of the Driver Settings dialog box will be initialized. For details on the setting items, refer to "About the items in the Settings dialog box."
Install the driver as described in "Installation."
To uninstall
*   Be sure to also remove the GR-55's USB cable.
Exit all applications before you begin the uninstallation.
Right-click the start button and then click "Programs and Features".
In the list, choose "GR-55 Driver", and click "Uninstall/Change."
*   The driver is not installed if GR-55 Driver is not displayed in the list.You do not need to uninstall the driver.
If a dialog box regarding User Account Control appears, click [Yes].
*   If you are asked to enter the password for an administrative account, sign in to Windows as a user whose Account Type is Administrator, and then perform the uninstallation.
The display will indicate "The installed GR-55 Driver will be uninstalled." and click the [OK].
When the message "Uninstallation was completed." is displayed, click [OK] to restart Windows.
Troubleshooting
Cannot install the driver
Check the status of the device
If the GR-55 is connected but cannot be used after waiting for 10 minutes, follow the procedure below and check the status of the device.
Right-click the start button and then click "Device Manager".
In the View menu, click "Devices by type".
Click "Sound, video and game controllers" or "Other devices" to display the GR-55 device.
When the GR-55 device appears, double-click it to open the "GR-55 Properties" screen.
Under the General tab, check the "Device status" field.
If the message in this field is "This device is working properly.", the driver installation is completed.
Otherwise, the driver installation may have failed.
See other topics in Troubleshooting for driver installation problems.
Is your computer connected to Internet?
To install this driver, your PC must be connected to the Internet.
Check that your PC is connected to the Internet (for example by using a Web browser), and then install the driver again by following the steps described in the "Installation" section.
Reconnect GR-55
The device recognition may have failed.
Disconnect GR-55's USB cable, turn off the power of GR-55 and turn it on again, and then reconnect it to your PC.
Install the driver manually
Depending on the Internet connectivity, the driver may not be installed automatically.
If this is the case, follow the procedure below to install the driver.
When the GR-55 device appears, right-click it, and then select "Update Driver Software".
Select "Search automatically for updated driver software".
Your PC starts searching for the driver, and the driver is installed automatically.
The installation is completed if the "Windows has successfully updated your driver software" message is displayed. Click "Close".
If the "System Settings Change" dialog box appears, click [Yes] to restart Windows.
Cannot select/use the GR-55 device
Was the driver installed correctly?
The driver may not be installed properly.See the "Cannot install the driver" section.
If you cannot use GR-55 after the driver is installed, reinstall the driver by following the procedure described in the "To reinstall" section.
Could the GR-55 be in use by other software?
Exit all applications that are using the GR-55, and turn the power of the GR-55 off, then on again.
If this does not solve the problem, use the procedure described in "To reinstall" to reinstall the driver.
Is the GR-55 WAVE/MIDI device name displayed?
If the device name is not displayed, exit all applications that are using the GR-55, and turn the power of the GR-55 off, then on again.
Did the computer enter a Sleep mode while the GR-55 was connected with its power turned on?
Was the USB cable disconnected and reconnected while the GR-55 was being used, or was the power of the GR-55 turned off, then on again?
If the USB cable is disconnected and reconnected while the GR-55 is in use, or if the power of the GR-55 is turned off, then on again, it may no longer operate correctly. If this occurs, exit all applications that are using the GR-55, and turn the power of the GR-55 off, then on again.
A number such as "2-" is now displayed at the beginning of the device name
Could you have connected the GR-55 to a different USB port?
If you connect the GR-55 to a different USB port, the operating system may automatically add a number to the beginning of the device name.
Even if this occurs, it will not cause any problems with the operation of the GR-55.
*   If you want to restore the device name that does not have this added number, connect the GR-55 to the same USB port as when you installed it, or reinstall the driver as described in "To reinstall."
The screen indicates "Device currently used by another application." and driver settings cannot be made
Are you using another application?
The driver settings cannot be changed while it is being used by an application.
No sound is heard; cannot playback or record
Did you make settings as described in "Before you begin" so that the GR-55 driver could be used?
The GR-55 cannot be used unless you make these settings. Refer to the sections on "Before you begin."
Could you have entered Sleep mode during playback or recording?
During playback or recording, did you turn the power of the GR-55 on/off, or disconnect and reconnect the USB cable?
If you turn the power of the GR-55 on/off or disconnect and reconnect the USB cable during playback or recording, the GR-55 will no longer be able to play back or record. Stop playback or recording, and then start playback or recording once again. If you are still unable to play back or record, quit all programs that are using the GR-55, then turn the GR-55 off and then on again.
Try adjusting the audio buffer size of the driver
If the size of the driver's audio buffer is too small, sound may not be produced, or it may be impossible to carry out normal playback and recording.
In such cases, you should refer to "Changing/checking driver settings," and increase the size of the buffer.
Sound played by your computer is inaudible or too soft
Could you have turned down the volume of the device or application in the Volume Mixer?
The system's Volume Mixer lets you adjust the volume for each device or application.
Open the "Control Panel," and switch "View by:" to "Category."
Click "Hardware and Sound," and then click "Adjust system volume."
The Volume Mixer will appear. From the "Device" pulldown menu, choose the device that you're using for playback, and adjust the volume.
*   Alternatively you can open the Volume Mixer by right-clicking the speaker icon located in the lower right of the Desktop and choosing "Open Volume Mixer."
Are you using voice communications software?
If you're using voice communications software, the volume of the audio device might be automatically adjusted according to the status of communications.
If so, disable automatic volume adjustment as follows.
Open "Control Panel," click "Hardware and Sound," and then click "Sound."
In the "Communications" tab, change the setting of the item "When Windows detects communications activity" to "Do nothing."
Part of the playback is wrong: e.g., notes are broken off prematurely, or some notes are lost
Problems may be solved by making the settings shown below.
Try adjusting the audio buffer size of your software
If your software allows you to adjust the audio buffer size, try changing the setting.
Normally, clicks and pops can be eliminated by increasing the buffer size.
If your software does not allow you to adjust the buffer size, or if adjusting the buffer size in your software does not solve the problem, you may be able to solve the problem by changing the driver's audio input/output buffer size.
Try adjusting the buffer size as described in "Changing/checking driver settings."
Try updating the driver of your display adaptor
You may be able to eliminate clicks and pops by updating the driver for the display adaptor installed in your computer.
Windows Update / Microsoft Update
You may be able to solve the problem by updating your system with "Windows Update" or "Microsoft Update" provided by Microsoft.
Check the power management settings
Open "Control Panel," click "System and Security," and then click "Power Options."
*   If the icon view is selected for the Control Panel, click "Power Options."
In "Choose or customize a power plan," choose "High performance."
*   If the "High performance" plan is not shown, click "Show additional plans."
In the High performance area, click "Change plan settings."
Click "Change advanced power settings."
In the Advanced Settings, click the "+" symbol for "Hard Disk," and click the "+"symbol for "Turn off hard disk after" to open it.
Click "Setting (Minutes)," and click the down arrow to change the setting to "Never."
Click [OK] to close the Power Options window.
Close the "Edit Plan Settings" screen.
"Performance Options" settings of System Properties
Open "Control Panel," click "System and Security," and then click "System."
*   If the icon view is selected for the Control Panel, click "System."
At the left, click "Advanced system settings."
*   If you are asked to enter the password of an Administrator account, sign in to Windows as a user whose Account Type is Administrator, then perform the settings again.
Click [Settings] of the Performance section, and then click the [Advanced] tab.
Select "Background services," and click [OK].
Click [OK] to close "System Properties."
Do the sample rate settings match?
You must set the sampling frequency that's been specified through the audio settings of the application so it matches the GR-55's sampling frequency.
If the Windows monitoring function is enabled, the input sound might be heard in duplicate (doubled), or a feedback loop (oscillation) might occur.
If so, disable the Windows monitoring function as follows.
In "Recording," select GR-55's "IN," and click "Properties."
*   If the above WAVE ports cannot be selected, a problem may have occurred. Refer to "Troubleshooting."
Open the "Listen" tab, and clear the check box "Listen to this device."
Click [OK] to close "Properties."
Audio clicks and pops occur in the playback or recording immediately after the system has started up, or immediately after the computer has been woken from a Sleep state
Wait a few moments before you perform playback or recording.
Clicks or pops may occur in the sound if a LAN is operating
Try disabling the LAN in the Device Manager.
Playback or recording is interrupted, and then you cannot resume playback or recording
Was your computer experiencing a heavy processing load?
If your computer was experiencing a heavy processing load while the GR-55 was being used, the GR-55 may no longer operate correctly. If this occurs, stop the playback or recording, then try starting playback or recording over again.
HecticArt
I swear to the gods above, I'm booking a flight to Japan, and slapping someone at Roland.
The Win 10 driver is complete junk, and it's beyond me how a company like this can't get something so basic worked out.
I've gone through the instructions several times. Completely uninstalled the drivers and ghosts. Wasted several hours, and the Librarian still crashes every time I click on a patch. It loads them all off of the 55 properly, so it's making the connection, but it's dead after that. I haven't been this frustrated trying to install something since DOS.
I'm glad I saved my Win 7 laptop. Shame on you Roland.
My apologies for the rant.
nobeil
I am having trouble with Librarian. It opens fine. I reads the patches fine. But if I click to highlight a patch windows pops up a window that librarian has stopped working and will shutdown the program. Running windows 10. Any one have a fix for this?
The GR-55 driver is working fine as well as Floorboard (an awesome program!). But Librarian keeps crashing when I try to highlight a patch. Frustrating :/
Thanks for any help in advance.
HecticArt
I got the Roland drivers sorted out, and Floorboard up and running on my Win 10 machine!
I'm still not happy with Roland's lack of attention to supporting the drivers, but that's a different story.
Now that I have Floorboard running like a champ, I'm having the same issue with the librarian that nobeil is having. The Librarian keeps crashing. Anybody else run into this?
Perhaps other GR-55 with Windows 10 users  will comment.
(No Windows 10 here )
