Xbox Midifier free app and VST Plugin available!
Started by Elantric, June 12, 2013, 05:37:16 PM
http://www.evergladesaudio.com/blog-evergladesaudio/item/72-xbox-midifier-free-app-and-vst-plugin-available
Xbox Midifier is a great tool for controlling any midi device or vst plugin wireless. It works with other gamepads too, but you may loose some controls.
Also inside a DAW, you can control any plugin that receives MIDI data. You can use the pads and triggers with great sensibility!
    It's not tested in all DAWS, so you might find some problems. Please let me know!.
    Inside MIDI PROGRAMMER, you can select any type of midi command, they are diferent for buttons (on/off), and for pads and triggers (fader/knob like).
    If you find problems with your gamepad connection, even pressing the ACTIVATE GAMEPAD button, try installing the XBOX LIBRARIES (Free).
    The VST plugin needs to be routed properly: the midi ouput from the midifier goes to the input of your VSTI.
