Changing patches delayed sound problem...
Started by angelej9, August 02, 2014, 07:50:34 PM
angelej9
Hello guys, i having problem with my gr 55, every time i change to another patch there a little bit delayed of sound, ex. Patch 1 to patch 2, there is gap when you push the pedal before it sound the patch 2, any suggestion?? Thanksss
As quoted from a similar topic last week
This gap/mute in GR-55 patch changes can't be fixed. Most get around this by using Control Assignments and stay on one patch per song.
look at top of forum for GR-55 FAQ
GR-55 FAQ: TOP THINGS TO KNOW
* GR-55 Ultimate Multi Control patches (solves the GR-55 long Patch change delay (with mute) issue)
Jim Williams Multiple Assignment Patches.
https://www.vguitarforums.com/smf/index.php?topic=5647.msg38806#msg38806
Learn multi-assignments by following all steps outlined here - then edit to suit YOUR needs.
Guitarplayer_10's  GR-55 Ultimate Multi Control patch step by step
https://www.vguitarforums.com/smf/index.php?topic=7267.msg50612#msg50612
Quote from: angelej9 on August 02, 2014, 07:50:34 PM
This is a known problem with rhe GR55. Most work by using assigns to build one patch per song :'(
angelej9
