GK-3 - GK hex PU Clearance Problems on American Strat
Started by ( . )( . ), March 25, 2016, 12:02:56 AM
I have a 1999 SSS American Strat which is set up just like I like. There isn't enough clearance between the pickguard and the strings to install the GK-3. I could cut the pickguard, but I'd rather get a new one that will work. My current one is a 3 ply, 11 hole. I'm looking for a single ply 11 hole I guess in white, but can't find one.
What is the thickness of my 99 3 ply? Is it .09"? If I could find one about half the thickness, I think it would work.
I found this, but it doesn't really match the guitar, and I don't even know if it's thin enough: http://www.stratcat.biz/099-1360-100.shtml
I also found this, which is just a tad thicker (.06") than the chrome, but will match the guitar. http://www.warmoth.com/Pickguard/StratPickguard.aspx
Help please...
stratrat
Just shim your neck angle back a bit - that gives you better string clearance over the body, making more space for the hex pickup. It'll make a world of difference to your whole setup too.
A few strips of wood veneer on the body side of your neck pocket is all it takes. Adjust saddles and pickups to suit, and you're sorted.
Trevor
Most hex pickups are housed in a radiused plastic housing, you can carefully remove said housing, place the hex in some shrink tube, carefully heat/shrink (carefully, the circuit boards are flexible/meltable plastic) to radius and it will give you a few MM's on all sides.Warning, won't be as pretty.
Details here
https://www.vguitarforums.com/smf/index.php?topic=410.0
If it's a 1999 Fender American Strat,
http://wurlitzerboston.myshopify.com/products/1999-fender-american-deluxe-stratocaster-maple-fingerboard-ash-body
learn how to use the Microtilt Neck angle adjuster Allen Screw  on the Neck Plate
Gk-3 install on a Strat follows identical principals as explained for a Strat FTP Pickup install doc here
http://www.fishman.com/support/tripleplay/pdf/tripleplay_tut10.pdf
and follow GK-3 Install here
http://roland.com/V-Guitar/howto_st.html
Tony Raven
While I've been known to shim a neck up, in every case I can hear a reduction in the guitar's tonal quality, even when using brass shim stock. The "micro-tilt" screws aren't much improvement. In general, I prefer keeping a Fender-style bridge as low as possible, & having dead-flat wood-to-wood contact in the neck pocket, to maximize tone & sustain. If the GK-3 is possibly a passing phase &/or maintaining the guitar's value is paramount, shimming is just fine as a kludge.
In this instance, I'd suggest get an inexpensive pickguard & rout a channel, as in this Squier piece --
Ten bucks & no fancy tools necessary. ELEGANT METHOD: drill a series of holes, file them together, sand until it's all smooth. FAST EASY METHOD: give up on that little strip of plastic between the hex & the bridge, just carve until there's room for the GK, so long as you leave room for its two screws AND the two pickguard screws (& maybe a notch for the cable).
