GR-55 - Sounds der Helden: Edge
Started by Singwas, May 19, 2014, 11:45:17 AM
Singwas
Hi!
This patch uses 3Tap Pan Delay with quarter and dotted eighth notes. How can I adjust the tempo, or where has it been set? The Ctrl-Button is used for the E-Bow-Simulation.
GR 55
Godin LGXSA
Roland Testgitarre
* Open the patch in the GR-55 Floorboard editor.
* Review the Delay FX used in the patch and change the Delay Time.
Singwas
Thank You. This means that there is no way to change tempo of 3Tap Delay by tapping?
GR 55
Godin LGXSA
Roland Testgitarre
QuoteThis means that there is no way to change tempo of 3Tap Delay by tapping?
Quite the opposite
* Open the Sounds der Helden: Edge  patch in the GR-55 Floorboard editor.
https://www.vguitarforums.com/smf/index.php?topic=2951.0
* Review the Delay FX used in the Sounds der Helden: Edge  patch
Observe Left Delay = dotted 1/8th note, Center Delay= sixteenth note,  Right Delay = quarter note
* Change the patch Tempo on the System Page to alter the delay times.
Yes, you can tap all the delays on the GR55.
Just set the CTL pedal assignment to tap tempo. Change the delay time on the delay all the way to the right. After i t reaches its maximum delay time it will set to note lengths. For Edge style delays set it to a dotted eights or dotted quarter note.
