BigClivedotCom
Started by Elantric, April 13, 2016, 11:00:11 PM
http://bigclive.com/
http://bigclive.com/makendo.htm
http://www.youtube.com/channel/UCtM5z2gkrGRuWd0JQMx76qA
http://bigclive.com/guides.htm
KIT AND SOFTWARE GUIDES.
All the information you need to assemble and use your kits and chips.
Mini RGB controller kit assembly guide.
RGB pixel kit assembly guide.
The pro-rgb MK-II kit assembly guide.
The pro-rgb kit assembly guide.
Knob based RGB controller kit assembly guide.
RGB floodlight PCB assembly guide.
Round MR16 RGB PCB assembly guide.
LED sign making panels assembly guide.
General chip connection and usage data.
When powered up, the RGB controllers will indicate their software version by making the display glow a single colour for about one second. To see the effects available click the matching link below.
Original red version.
Green version.
Mini controller blue version.
Click here for more fun things to make and do.
http://bigclive.com/links.htm
Neat chunky aluminium USB light.
How to make Clear Glass PCBs
FreeTime
What a great series of videos. At least he takes the DMX fire machine into the hallway before he uses it.
tothoseofus
Wow...
So I'm supposed to be stabbing with the soldering iron¿
I've been doing it wrong all these years.
(Luckily the whole thing was a joke. He apparently had to add some resistors to the bottom to get some sparking. I wonder how hot his soldering iron was to even come close to working with that method)
Quote from:  philjynx
The great thing we learn on this forum. That was really enlighting!
I watched it with the sound off...it was even MORE entertaining!   ::)
I wonder if he has any tips for using heat shrinkable tubing. When I use that stuff it generally catches on fire before it shrinks.Then it shrinks. :)
Quote from: chrish on January 28, 2019, 09:07:31 AM
have to use the good heatshrink tubing - not the flame prone stuff from Harbor Freight
