VG-99 - Global Setting - main output
Started by Rami, July 06, 2014, 01:10:31 AM
Rami
Hello Everyone
Anyone  knows why when I change the main output select to line/phone/jc 120 atc.  it affects only 1/4  ports  and no effect on  the XLR ports?
how do I change it
QuoteAnyone  knows why when I change the main output select to line/phone/jc 120 atc.  it affects only 1/4  ports  and no effect on  the XLR ports?
how do I change it
The VG-99's Main 1/4" outputs can be configured to drive different amp types - using the Output Select function
Also know the VG-99's Volume knob only affects the Headphone Out and the Main 1/4" outputs, and not the "SUB Out XLR Balanced outputs. The plan is that you do not ruin the FOH PA mix if go over and change the stage Volume mid set.
The VG-99's 'Sub Out XLRS" are intended to directly feed a PA, and will always have the COSM Amp CAB Model Sims always engaged - no way to disable AFIAK.
Rami
