Importing patches, problem...
Started by iainaw, June 24, 2014, 10:00:07 AM
iainaw
Hi so am getting sorted with my vg 99 rig, have now got a computer solely dedicated to the vg... And I've got the complete patch data base on the computer and I've been going through them and some are really really cool... Here's the problem I bring up the patch in the vg 99 editor and all is well... I then try to save the patch to my vg, but once saved to a preset it sounds all different
What am I doing wrong?..
Cheers once again!
I hope soon I'll be able to be knowledgable enough to help others ... But just the last few hurdles and then I'm off
As an aside I've now got the next 4 weeks with gigs every weekend so can really (hopefully) tune the vg for live work... I'll post videos when I get the chance!
Cheers
VG-99 & FC 300, GR-20, Mesa boogie Triaxis, TC Electronics G-Force, Malmsteen Strat, Peavey Wolgang (with internal GK-3), Jackson Dinky, 50th Anniversary Strat, And other stuff ... Too much stuff ask my wife!...
**** Be sure to use the latest version 1.01 of the VG-99 Editor! and version 1.04 firmware installed in your VG-99
VG-99 FAQ: TOP THINGS TO KNOW
iainaw
First thing I did was do the firmware update and the editor was downloaded from the Roland web and is the latest!
iainaw
Love a learning curve I'm going to ski down this one when I'm done!
iainaw
might be data corruption at the USB port type - avoid using a USB 3.0 port
read
USB 3.0 compatible chipsets for Audio Interfaces
https://www.vguitarforums.com/smf/index.php?topic=8562.0
  - its MUCH preferred to use a USB 2.0 port to connect Roland gear.
On the VG-99, and the user to user shared patches for download here at VGuitarforums, Be sure you understand the process of "IMPORTING SMF FILES" on the VG-99 Editor
READ FIRST - VG-99 Patch Submission Format+How to SAVE and LOAD PATCHES!
https://www.vguitarforums.com/smf/index.php?topic=64.0
papabuss
#6
Excellent link.
(Also) watch the videos at  the bottom of Elantric's help:
iainaw
Again.  Thankyou so much chaps!!!... Will sit down tomorrow and have a play!!!...
respect.
I've run into this before on the GR-55 & on the VG-99.  I think the driver sometimes gets confused after encountering certain basic issues (like trying to write a patch without the proper device selected/cable connected).  Once you make a goof like that, it seems to screw up patch writes.  The most common symptom is that the title changes & the patch does not...
More here:
https://www.vguitarforums.com/smf/index.php?topic=9808.msg70344#msg70344
To fix, simply reboot and be very careful with device selection & physical cabling before attempting to write patches.
This may be a unique-to-PC issue.  (Most fix-by-reboot issues are!)
Shawn
Also be sure to close down all other apps when the VG-99 Editor or VG-99 Librarian is running.
Quote from: Elantric on June 24, 2014, 01:25:04 PM
Yes, that too!
