VG-99 - Changing the Connection Sequence (CHAIN)
Started by Brak(E)man, October 03, 2012, 02:21:18 PM
Is it just me or isn't changing the position of cosm guitar possible with the editor ???
Since i haven't found a way I use the chain selector on the VG 99 instead,
f.i. when i want the normal pickup before an amp but the cosm guitar after,
then sending the patch back to the editor etc.
i know how to reroute but my q is if it's possible to move the cosm guitar with the editor
the manual state this
QuoteChanging the Connection Sequence (CHAIN)
    You can drag and drop each effect to any desired position (between one effect and another) in the effects rack screen to change the sequence in which the effects are connected.
but doesn't mention moving the cosm guitar
and I can't find that in the editor, in the VG99 chain window it's easy
Sorry it was way to obvious for my brain  ::)
a real brain fart ,
it's in the effect chain window in the editor not in the cosm guitar dito
or master section , mixer etc.
which i guess makes sense but not to me,
no matter problem solved.
jburns
just right click one of the modules and drag it in between where you would like it =)
