Fiddlicator IR Cab Loader for IOS
Started by Elantric, October 29, 2015, 03:29:44 PM
https://itunes.apple.com/us/app/fiddlicator/id813106474?mt=8
Description
The Fiddlicator is an audio tool which can simulate various kinds of acoustic environment by the convolution of the input signal with a custom impulse response.
It was developed to simulate an acoustic body resonance for electric musical instruments (mainly the electric violin), but it can also be used for a cab simulation with proper impulse response files (not included).
The impulse response files can be imported via iTunes share or via 'Open in' option from another application.
The Fiddlicator is not appropriate to use as convolution reverb engine, because it can not process impulse response files longer than ~0.35 sec. (1.4 sec. with Fiddlicator Plus & MIDI extension)
See demo videos at: http://fiddlicator.wordpress.com/news/
Facebook page:
https://www.facebook.com/Fiddlicator
Main features:
- main filter is based on convolution
- own custom IR kernel files could be imported
- 6-band parametric equaliser (low-shelf, 4xpeak, high-shelf)
- delay & reverb
- high-pass and low-pass filter on input
- low latency
- IR files could be imported from standard sound files (wav...) or csv file (via 'Open in...' or iTunes share)
- mono input/output 44.1kHz (allows channel selection)
- Audiobus and IAA support
- background audio mode
Fiddlicator Support
What's New in Version 0.9.7
- new Audiobus library (2.2.2) with iOS9 support
- stereo output from reverb
- convolution algorithm is slightly improved
http://www.elevenrackpresets.com/forum/ubbthreads.php?ubb=showflat&Number=42171
zacflame wrote>
Just found a program that loads ownhammer ir, then use jamup and fiddlecator in audio bus , the ownhammer ir brings a whole new sound dimension, anyone ever try something like this ?Can't upload a screen shot, also just using jamup as is , tonestack and bias you can turn off the cabs , anyway the app is called fiddlicator, it has a eq,reverb and delay, you need a program called I fun box on your computer, this creates a file system on your ipad you can see on your computer, then simply transfer the files from computer to ipad, load up audio bus with fiddlecator being the output,and your good to go
http://www.i-funbox.com/
